[postgis-users] [!! SPAM] multipolygon to single polygon
Nicolas Ribot nicolas.ribot at gmail.com
Thu Apr 26 09:04:26 PDT 2012
This polygon cannot be represented as a single object, as it contains 2
separate polygons.
Only a MULTIPOLYGON can represent this object.
If you want to generate 2 objects from this polygon, re-dump the final
union, and you will extract each individual part representing your coverage.
Nicolas
On 26 April 2012 17:57, Mehmet Erkek <merkek at reidin.com> wrote:
> :) thanks Nicolas. ****
> Here is my data . it has two polygons in it. I want to convert this to one
> single polygon.. I have many raws like this. this is just an example. ****
> MULTIPOLYGON(((44.23219 37.044958,44.232267 37.044496,44.232391
> 37.043847,44.232478 37.043021,44.232565 37.042165,44.232692
> 37.04128,44.232701 37.040335,44.232281 37.03922,44.231698
> 37.038566,44.231192 37.03809,44.230647 37.037585,44.229867
> 37.037107,44.229007 37.036688,44.228148 37.036181,44.227327
> 37.035762,44.226585 37.035314,44.225252 37.034959,44.224662
> 37.035073,44.223167 37.035329,44.22234 37.035501,44.221435
> 37.035613,44.220767 37.035608,44.220257 37.035575,44.219985
> 37.035308,44.219949 37.034924,44.22023 37.034394,44.220824
> 37.033896,44.221616 37.033311,44.222367 37.032843,44.223552
> 37.032172,44.223988 37.031821,44.225014 37.031015,44.225607
> 37.030635,44.226243 37.029901,44.226839 37.029284,44.227997
> 37.027349,44.228435 37.02682,44.228793 37.02635,44.228837
> 37.025848,44.228843 37.025317,44.228808 37.024814,44.228589
> 37.023248,44.228838 37.021861,44.229077 37.021538,44.229633
> 37.020921,44.230188 37.020482,44.23082 37.020043,44.23173
> 37.019429,44.231851 37.019104,44.232053 37.018515,44.231979
> 37.018072,44.231513 37.017537,44.231085 37.01718,44.230658
> 37.016704,44.230505 37.01629,44.230509 37.015876,44.230867
> 37.015436,44.231421 37.015026,44.23221 37.014677,44.232958
> 37.014445,44.233632 37.013888,44.234427 37.01286,44.234828
> 37.012124,44.235617 37.011716,44.236522 37.011574,44.237897
> 37.011494,44.239662 37.011742,44.240329 37.011805,44.241114
> 37.01178,44.242294 37.01167,44.243317 37.01144,44.244028 37.01109,44.244266
> 37.010449,44.244509 37.009682,44.244714 37.008827,44.244995
> 37.008179,44.245766 37.005272,44.246167 37.004448,44.246804
> 37.003566,44.247163 37.002948,44.24875 37.001304,44.250062
> 36.999487,44.252713 37.00048,44.253684 37.000577,44.255382
> 37.000625,44.256983 36.999849,44.259312 36.999315,44.261689
> 36.999121,44.263969 36.999412,44.26688 36.999412,44.268918
> 36.999752,44.269597 36.999752,44.271441 36.999946,44.273333
> 37.000916,44.273867 37.002226,44.274643 37.002954,44.275662
> 37.003294,44.277215 37.002857,44.278379 37.002663,44.279932
> 37.003706,44.280514 37.004288,44.281873 37.006035,44.283522
> 37.006811,44.285997 37.007394,44.288083 37.008801,44.288617
> 37.010062,44.289199 37.010984,44.290654 37.011809,44.292449
> 37.013022,44.293759 37.013604,44.294584 37.014744,44.29473
> 37.015472,44.295409 37.016927,44.296622 37.018286,44.298078
> 37.018577,44.300261 37.018334,44.30225 37.01751,44.303123
> 37.016927,44.304627 37.016394,44.306326 37.016976,44.307975
> 37.017461,44.309528 37.017364,44.31011 37.018868,44.308363
> 37.020396,44.304725 37.023404,44.302105 37.025636,44.300892
> 37.026413,44.299873 37.027189,44.299436 37.028062,44.299436
> 37.02913,44.299776 37.030197,44.300892 37.030731,44.301959
> 37.030925,44.3039 37.030439,44.304773 37.030925,44.303366
> 37.032671,44.30094 37.036165,44.301668 37.037766,44.302529
> 37.041003,44.23219 37.044958)),((44.253299 36.985138,44.253097
> 36.984954,44.252473 36.984536,44.252044 36.984179,44.251695
> 36.983763,44.25162 36.983349,44.252098 36.982673,44.252691
> 36.982322,44.253557 36.982061,44.254041 36.981849,44.253299 36.985138)))**
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Nicolas
> Ribot
> *Sent:* 26 Nisan 2012 18:37
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] [!! SPAM] multipolygon to single polygon***
> Sorry, I read too quickly.****
> I suggested what you tried ;)****
> what query are you running and what are your data to obtain multipolygons ?
> Nicolas****
> On 26 April 2012 17:32, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:****
> Hi,****
> As Julien suggested, you could st_dump to explode multipolygons into
> polygons, then union them.****
> It will produce a single polygon unioning all others:****
> with t as (****
>     select (st_dump(geom)).geom ****
>     from my_table****
> ) select st_union(geom) from t;****
> Nicolas****
> On 26 April 2012 17:22, Mehmet Erkek <merkek at reidin.com> wrote:****
> Hi Juilen, thanks for quick answer. ****
> I have 1 geometry and 1 row on the table. this geometry is multiploygon
> which consists of 4 polygons.****
> I want to convert this mutlipolygon to one single polygon..****
> Any idea how I can do this?****
> I hope it is clearer now.****
> Thanks.****
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *ju
> *Sent:* 26 Nisan 2012 18:02
> not clear...
> 1) if you have 4 polygons in 4 rows table distinct, this is not a multi
> object issu. for  this case use
>  dissolve to group polygone into only one, this is not a topic of dump.
> 2) if you have 1 geometry and 1 row on the tablme, so this is a multi
> object topic
> you must sperate the differents objet of the collection
> here : http://www.postgis.org/docs/ST_GeometryN.html****
> --Extracting all geometries (useful when you want to assign an id)****
> SELECT gid, n, ST_GeometryN(the_geom, n)****
> FROM sometable CROSS JOIN generate_series(1,100) n****
> WHERE n <= ST_NumGeometries(the_geom);****
> best regards, julien
> Le 26/04/2012 16:27, Mehmet Erkek a écrit : ****
> I have multipolygons which I would like to convert a single polygon. is
> there a way to do this? please check the attached image. I tried st_dump
> and afterwards st_union , but eventually I get a multipolygon again, not
> polygon. ****
> *Mehmet Erkek*****
> www.REIDIN.com <http://www.reidin.com/> ****
> This message is for the designated recipient only and may contain
> privileged, proprietary, or otherwise private information. If you have
> received it in error, please notify the sender immediately and delete the
> original. Any other use of the email by you is prohibited. Please Consider
> the Environment Before Printing This Email
> _______________________________________________****
> postgis-users mailing list****
> postgis-users at postgis.refractions.net****
> http://postgis.refractions.net/mailman/listinfo/postgis-users****
> Julien-Pierre Guilloux****
> Service scientifique - Géomatique****
> Parc National des Ecrins****
> Domaine de Charance****
> 05 000 GAP****
> tél : 04.92.40.20.10****
> fax : 04.92.52.38.34****
> julien.guilloux at ecrins-parcnational.fr****
> the Environment Before Printing This Email ****
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120426/5f62269e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120426/5f62269e/attachment.png>
Name: Screen shot 2012-04-26 at 6.02.25 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120426/5f62269e/attachment-0001.png>
