[postgis-users] Topology GetRingEdges
    Bob Pawley
    rjpawley at shaw.ca
    Fri Apr 27 13:11:27 PDT 2012
Hi
I have established the schema and tables as outlined in the documentation example 11.8 TopoGeometry Constructors.
However, I am still missing something.
When I run GetRingEdges -
    select  topology.GetRingEdges('TEST', 1), entities.wkb_geometry
    from entities, num_search
    where st_intersects(entities.wkb_geometry, num_search.the_geom2);
The return are only the geometries which are actually intersected by st_intersects.(In this particular case only four of the eight lines that make up the polygon).
I was hoping the whole closed geometry  to be returned.
What am I missing??
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120427/f8ad784f/attachment.html>
