[postgis-users] Topology GetRingEdges
Bob Pawley rjpawley at shaw.ca
Mon Apr 30 08:30:56 PDT 2012
Well, it would seem to me that I need to identify the geometry at some point
as a start (and end) for "walking" the geom, hence, the ST_Intersects.
I've attempted to use the geom column in the edge_data table but so far
haven't been able to make this work (errors returned) -
select topology.getringedges(edge_data, 1), entities.wkb_geometry
    from "TEST".edge_data, entities
    where "TEST".edge_data.edge_id = 1
So far, this is the only combination that I can make work.
My problem may be that I am confused on the atopology varchar for which the
GetRingEdge is looking, if it isn't the geom of table edge_data.
And I am also wondering why the TEST schema produced by toTopoGeom requires
double quotes in order to be recognized?
Or am I entirely missing the point?
Bob
-----Original Message-----
Sent: Monday, April 30, 2012 2:51 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Topology GetRingEdges
On Fri, Apr 27, 2012 at 01:11:27PM -0700, Bob Pawley wrote:
> Hi
> I have established the schema and tables as outlined in the documentation
> example 11.8 TopoGeometry Constructors.
> However, I am still missing something.
> When I run GetRingEdges -
>     select  topology.GetRingEdges('TEST', 1), entities.wkb_geometry
>     from entities, num_search
>     where st_intersects(entities.wkb_geometry, num_search.the_geom2);
> The return are only the geometries which are actually intersected by
> st_intersects.(In this particular case only four of the eight lines that
> make up the polygon).
> I was hoping the whole closed geometry  to be returned.
> What am I missing??
I don't understand what your query above is trying to select.
You are calling GetRingEdges with a constant edge id, why so ?
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
