[postgis-users] st_value/st_world2rastercoordx error
SIG CEN L-R sig at cenlr.org
Wed Aug 1 23:29:23 PDT 2012
Thanks a lot Bborie,
As you suggested there was a null geometry in my table and the second "error" you discovered was that I used non tiled raster in the database.
http://si.cenlr.org/2012/08/01/postgis-raster-suite
I forgot to "reply to all" so I put our exchange below
Thanks again,
Mathieu
Mathieu BOSSAERT
Responsable du système d'information du CEN L-R
04 67 29 90 65 - sig at cenlr.org
----- Mail original -----
De: "Bborie Park" <bkpark at ucdavis.edu>
À: "Mathieu Bossaert (CEN L-R)" <sig at cenlr.org>
Envoyé: Mercredi 1 Août 2012 19:05:47
Objet: Re: [postgis-users] st_value/st_world2rastercoordx error
Ah. If each table only has one row, then definitely do not use
ST_Intersects. ST_Intersects should be used in the normal situation (1
table = many rows). Also, one thing to keep in mind is that a single
field in PostgreSQL can only hold 1 GB of data. I don't know if your
rasters exceed 1GB in size, but that is something to keep in mind.
I'll have to add a check for when the geometry is null in that
function... I'll ticket it.
-bborie
On 08/01/2012 03:16 AM, SIG CEN L-R wrote:
Hi bborie,
Thanks for the answer. It helps me a lot for this problem and generally with postgis ratser.
Basically my ratsers were stored in the database as only one tile (one raster = one table with one row)
=> when i tried to enhance my query by using the st-intersects() operator, the execution grew up!
So now I store my rasters with indexed tile (100x100px). The query is now very fast!
For the second problem, you were right, one of my row had a null geometry value!
Thanks again,
Mathieu Bossaert
Mathieu BOSSAERT
À: "Mathieu Bossaert (CEN L-R)" <sig at cenlr.org>, "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Envoyé: Mardi 31 Juillet 2012 16:06:56
Can you isolate the geometry that is causing the NaN? Maybe something like
SELECT
rowid,
ST_X(geometry)
ST_Y(geometry)
FROM mygeometrytable
The error message indicates that somehow a NaN is being passed to ST_World2RasterCoordX...
Also, your query isn't ideal. You should add another WHERE clause dealing with the intersection of the rast and the geometry.
UPDATE export.tous_point_espece_selon_format_esri SET
pente_mnt = ST_VALUE(rast, geometrie, true)
FROM raster.pente_mnt30
WHERE code_insee LIKE '30%'
AND ST_Intersects(geometrie, rast)
-bborie
On Tue, Jul 31, 2012 at 2:09 AM, Mathieu Bossaert (CEN L-R) < sig at cenlr.org > wrote:
Good morning,
first of all I want to thank the PostGIS community for the great job she does.
I am a french user of postgis since 2006 and it helps us a lot in our mission to preserve landscapes and biodiversity.
Since a few month we use rasters function in order to characterize species distribution.
I have a problem with 1 of 5 raster table containing a dem.
When I try to populate an elevation attribute of a point layer from this raster I get an error. To workaround this problem I use pg-script to run this update line after line.
Is there a way to run this command, skipping the error.
Here is the query :
UPDATE export.tous_point_espece_selon_format_esri SET pente_mnt = ST_VALUE(rast, geometrie, true)
And here is the error (sorry it's in french)
ERREUR: syntaxe en entrée invalide pour l'entier : « NaN »
CONTEXTE : PL/pgSQL function "st_world2rastercoordx" lors de la conversion de la valeur de retour au type de retour de la fonction PL/pgSQL function "st_value" line 13 at RETURN
Thanks again,
Mathieu Bossaert
Mathieu BOSSAERT
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120802/774b5c54/attachment.html>
