[postgis-users] Could not add all rasters to a table
Paragon Corporation
lr at pcorp.us
Wed Aug 15 15:09:58 PDT 2012
Olivier,
You can use FWTools or Tamas nightly builds.
http://www.postgis.org/documentation/manual-2.0/RT_FAQ.html#id2979398
Both have gdalinfo.exe. Tamas always has the latest and greatest.
Hope that helps,
Regina
h <http://www.postgis.us> ttp://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Olivier
Courtin
Sent: Wednesday, August 15, 2012 10:48 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Could not add all rasters to a table
Hi Park,
I could not find gdalinfo.exe on my windows machine. I have installed
postgis 2.0. Should I install gdalinfo separately? I could not google to the
application download. Where should I find it?
I could not find scale x/y values for the raster files. Moreover, I do not
see any problem in viewing them in ArcMap. They might overlap little bit on
the edges. But that is usually the case with raster images.
Any help to sort of the problem. Thanks.
Date: Tue, 14 Aug 2012 11:43:51 -0700
Subject: Re: [postgis-users] Could not add all rasters to a table.
Message-ID: <502A9C67.5040901 at ucdavis.edu>
Content-Type: text/plain; charset=ISO-8859-1
The error is just that: at least one raster isn't aligned with the other
rasters being added to that table. One way to see what could be going on is
to use gdalinfo on the four rasters. Check the values for the upper-left
corner, scale and skew. The scale and skew should be the same while the
upper-left corners should be divisible without a remainder...
(rast1X - rast2X) / scaleX = whole number
(rast1Y - rast2Y) / scaleY = whole number
If all that looks good, post the outputs from gdalinfo for all four rasters
so that I can take a look and see if there are strange floating point
issues...
-bborie
On 08/14/2012 11:32 AM, Melpati, Muni wrote:
> Hi,
> I am getting this error "raster with different alignment found in the set
of rasters being converted to postgis raster" while I load all four jpg
files into a new table. When I view them ArcMap they just seems to align
well.
> What must be going wrong?
> Here is the text in the bat file:
> path=%path%;"E:\PostgreSQL\8.4\bin
> cd /D "%~dp0"
> raster2pgsql -I -C -e -Y -F -s 26986 -t 300x300 -l 2,4
> F:\PostGIS\raster\*.jpg private_schema.rasterly1 | psql -h localhost
> -U postgres -d gis_raster -p 5433
> pause
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120815/3c870cfa/attachment.html>
