[postgis-users] Creating points along a line for every second?
James David Smith
james.david.smith at gmail.com
Fri Aug 17 12:17:32 PDT 2012
Hi everyone,
I'm flirted around this problem for a while, so I hope I'm not bein
annoying by being repetative, but I've been tearing my hair out trying to
do it. The problem is that I have a file of lines (geometry). in a table
called temp4 The format of the table is, simplified,
line
start_time
end_time
series (I generated this as a count of the seconds difference between the
above time fields. I thought it would be useful)
So for example my table (temp4) might look like this:
line || start_time || end_time
|| series
line_geom || 12:07:17 || 12:07:20 || 3
line_geom || 12:07:17 || 12:07:20 || 2
line_geom || 12:07:17 || 12:07:20 || 1
line_geom || 12:07:21 || 12:07:26 || 6
line_geom || 12:07:21 || 12:07:26 || 5
line_geom || 12:07:21 || 12:07:26 || 4
line_geom || 12:07:21 || 12:07:26 || 3
line_geom || 12:07:21 || 12:07:26 || 2
line_geom || 12:07:21 || 12:07:26 || 1
Now what I want to do is split the lines into points, with a point for each
second. Evenly spaced along the line. So if the line is 10 metres long and
the difference between the start and end is 10 seconds then I want to
create 9 points at 10% along the line, 20% along the line, 30% along the
line etc up to a point which is 100% along the line i.e. the end of the
line. I don't need a new point at the start of the line as I have that
stored already.
So I've been trying something like this, but it's wrong. But maybe along
the right lines.
SELECT st_line_interpolate_point(line, 1/series::float)) as new_point
FROM temp4
Taking the first few rows of my data, the percentages along the lines I
want to generate are as follows. I need to find a way to get these values
into the st_line_interpolate_line function.
line || start_time || end_time ||
series || percentage along line
3 || 0.33%
|| 0.67
|| 100%
Sorry for the long explanation. Hope that you understand where I am coming
from. Grateful for any ideas please!
Thanks
James
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120817/3e6d9033/attachment.html>
