[postgis-users] Postgis raster layer plugin : displaying troubles into Qgis 1.8
Bborie Park
bkpark at ucdavis.edu
Fri Aug 17 15:48:55 PDT 2012
Could you try GDAL svn-trunk? You would need to compile it. Some fixes
were done in GDAL svn-trunk due to a bug that was corrupting output from
PostGIS.
-bborie
On 08/17/2012 03:36 PM, lcelati at latitude-geosystems.com wrote:
> Hello,
> Thank you for your reply (Postgis userList), i use Qgis 1.8 (compiled
> with Gdal 1.9.1)
> Regards.
> What version of GDAL are you running? QGIS uses GDAL under the hood to
> access PostGIS Raster.
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
