[postgis-users] Problems with importing postgis.sql after building postgis
Bborie Park bkpark at ucdavis.edu
Mon Aug 20 09:54:33 PDT 2012
You may want to check postgis-2.0.so with ldd.
-bborie
On 08/20/2012 04:11 AM, Ishwinder Singh wrote:
> Seems like that i am the only one having this problem .. :)
> Thanks.
> On Sat, Aug 18, 2012 at 1:59 AM, Ishwinder Singh <ishwinder at enbake.com>wrote:
>> I am trying to build postgis 2.0.1. The build completes successfully but
>> importing postgis.sql says this error
>> json_tokener_errors .. symbol not found
>> i am sure that lib json-c compiled successfully
>> and the lib is in the dynamic library path(verified through ldconfig -v)
>> any ideas on what can be the problem ?
>> Thanks & Regards,
>> Ishwinder Singh
>> Enbake Consulting.
>> Phone: +91-987-28-20737
>> Skype: enbake.
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
