[postgis-users] irregular tiling with raster2pgsql - imported raster has nodata value on the edge
Bborie Park bkpark at ucdavis.edu
Sun Aug 26 12:28:24 PDT 2012
Currently, that behavior is as expected due to the application of the
specified tile size from the upper-left corner.  To minimize the tiles
with large swaths of NODATA, you should try to use a tile size that is
cleanly divisible (no remainder) by the raster's width and height or a
size with a large remainder.  I usually recommend tile sizes of
100x100 or smaller though sizes around 50x50 are even faster.  In
terms of performance, the smaller the time size, the better the
performance.
-bborie
On Sun, Aug 26, 2012 at 10:22 AM, Jakub Hettler <jakub.hettler at gmail.com> wrote:
> Hi all,
> I would like to ask if there is a way how to import tiled raster into
> PostGIS through raster2pgsql, but I need to make tiled raster, say 256x256,
> but at the end of raster I have last tiles (on the east and south side)
> which is on half out of the original raster (raster ends fe in the middle of
> last tile). If I try to load imported raster into QGIS or use gdal_translate
> I have nodata value on this place in the raster. Is there a way how to
> import the raster with the smaller last tiles on the east and south edges?
> Thanks
> Jakub
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
