[postgis-users] RAM requirement of shp2psql and psql command for 368 MB data
Paul Ramsey pramsey at opengeo.org
Mon Aug 27 15:03:52 PDT 2012
Both commands should stream the data, not load it into memory, so you
should not see any RAM problems at all.
P.
On Mon, Aug 27, 2012 at 5:27 AM, Tanja Kantola <tmkantol at gmail.com> wrote:
> I haven't got PostGIS installed and have never used it.
> However, I would quickly need to make an estimate of how much RAM
> space would it require to run  shp2psql  and psql -f commands on shape
> dataset, which size is 368 MB.
> Does any experience user have an estimate of how light/ heavy would
> these processes be?
> postgis-users mailing list
