[postgis-users] Computing a centroid on GEOGRAPHY objects
Ed Linde edolinde at gmail.com
Thu Dec 6 14:15:25 PST 2012
So does this mean that if the set of points span across 2 UTM zones, then
its not possible to compute their centroid location?
The ST_Buffer does say that it won't work if the points are across multiple
UTM zones.
On Thu, Dec 6, 2012 at 11:05 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> If the points of the features are truly spread out across the world,
> the centroid is pretty meaningless. If the points of any given feature
> are relatively compact, then using an approach with _ST_BestSRID would
> work (see the def'n of ST_Buffer(Geography) for an example).
> P.
> On Thu, Dec 6, 2012 at 1:55 PM, Sandro Santilli <strk at keybit.net> wrote:
> > On Thu, Dec 06, 2012 at 09:34:53PM +0100, Ed Linde wrote:
> >> I know there is a centroid computation function in Postgis, but it
> seems to
> >> only work on a geometry type.
> >> The lat/long coordinates are spread all across the globe and hence I
> cannot
> >> convert it to local UTM formats because there is a discrepancy when
> going
> >> across different zones!
> > I wonder how the centroid of points spread across the globe would look
> like.
> > Jules ?
> > --strk;
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121206/5186bf89/attachment.html>
