[postgis-users] ST_Polygonize thows an error
Jeff Lake jeff at michiganwxsystem.com
Wed Dec 12 11:48:35 PST 2012
I using the following query
SELECT ST_Polygonize(the_geom) FROM (SELECT
ST_AsTEXT(the_geom),date,cntr_value AS the_geom FROM li_poly_000 ORDER
BY cntr_value desc) as foo;
the Error:
ERROR:  function st_polygonize(double precision) does not exist
LINE 1: select ST_Polygonize(the_geom) from (select st_astext(the_ge...
HINT:  No function matches the given name and argument types. You might need to add explicit type casts.
PostGisFullVersion();
POSTGIS="2.0.1 r9979" GEOS="3.3.6-CAPI-1.7.6" PROJ="Rel. 4.8.0, 6 March 2012" LIBXML="2.7.6"
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121212/25d810e3/attachment.html>
