[postgis-users] Build Issue postgis-2.0.2 (LDFLAGS is overwritten when creating the postgis-2.0.so)
Prasanta Chinara xchinu at yahoo.com
Wed Dec 12 16:03:14 PST 2012
Summary: LDFLAGS is overwritten when creating the postgis-2.0.so
hi,
I have postgresql-9.2.2 package installed before I try to create an RPM package for the postgis-2.0.2;
I updated the spec file with an LDFLAGS that has -Wl,-rpath set to libgoes_c.so.1 and libjosn.so.0.
During the rpm build process the postgis/Makefile is including:
/lib/pgsql/pgxs/src/makefiles/pgxs.mk which in turn includes:
/lib/pgsql/pgxs/src/Makefile.global and
/lib/pgsql/pgxs/src/Makefile.shlib and
/lib/pgsql/pgxs/src/Makefile.port
lib/pgsql/pgxs/src/Makefile.global is the one which is overriding LDFLAGS with the following snippets:
225 ifdef PGXS
226   LDFLAGS = -L$(libdir)
227 else
228   LDFLAGS = -L$(top_builddir)/src/port
229 endif
230 LDFLAGS += -L... # all library locations required for postgresql build and it DOES NOT include geos or json.
351 rpathdir = $(libdir)
352
353 ifeq ($(enable_rpath), yes)
354 LDFLAGS += $(rpath)
355 endif
'appreciate any help/pointers how to fix it.
Or let me know if I need to file a bug.
thank you,
Prasanta.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121212/0077d0c3/attachment.html>
