[postgis-users] CityGML in PostGIS - 3D City Database released
Felix Kunde
felix-kunde at gmx.de
Mon Dec 17 01:04:37 PST 2012
hm should I laugh or cry?
Do not use the psql console. EDIT the batchfile with a text editor. Right
click on the file and then edit (or "Edition" in french). A text editor
should be opened (like Windows Editor) and you can change the parameters
(see screenshot). Save your changes and then double click the .bat-file.
You MUST install PostGIS 2.0 in order to work with the 3D City Database. It
contains elements that are unknown to PostGIS 1.4. You will get some
"unknown parameter" errors which forces the script to stop. Get PostGIS 2.0
installed on you PostgreSQL server.
Felix
> -------- Original-Nachricht --------
> Datum: Sun, 16 Dec 2012 11:26:22 -0800 (PST)
> Von: babou <hiba.maalaoui at gmail.com>
> An: postgis-users at postgis.refractions.net
> Betreff: Re: [postgis-users] CityGML in PostGIS - 3D City Database
> released
> <http://postgis.17.n6.nabble.com/file/n5002072/Sans_titre.png> hi,
> I introduced the right parameter of .bat file but it's the same result :(
> I used postgresql-4.8.14-1-windows and postgis-pg84-1.4.0-2
> there are other version of postgis which I can test them?
> Felix thank you very much for your reply
> http://postgis.17.n6.nabble.com/CityGML-in-PostGIS-3D-City-Database-released-tp4998980p5002072.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121217/b4539eeb/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121217/b4539eeb/attachment.png>
