[postgis-users] Insert into
    Nicolas Ribot
    nicolas.ribot at gmail.com
    Tue Dec 18 11:12:41 PST 2012
Sorry, I read to fast, did not notice "down" is a column name.
What is the result of the query used in the insert statement ? Does it
produce values for the 3 columns ?
Could you also post the branch_point function ?
Nicolas
On 18 December 2012 19:59, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
> Hi Bob,
> The insert statement list only 3 columns. No other columns can be filled.
> If your trigger function is intended to insert other columns values, then
> you have to define an BEFORE INSERT.
> An AFTER INSERT trigger cannot modify values, as insertion was already
> done.
> Nicolas
> On 18 December 2012 19:39, Bob Pawley <rjpawley at shaw.ca> wrote:
>>   Maybe my mind has just gone numb – but I can’t figure out what is
>> wrong.
>> I run this expression
>> insert into pipe(line, down, id)
>>     (select st_makeline(st_centroid(num_search.the_geom7),
>> st_endpoint(bob.edge_data.geom)),
>> st_endpoint(bob.edge_data.geom)), 1 --pipe_num
>>     from bob.edge_data, num_search
>>     where st_intersects(bob.edge_data.geom, num_search.the_geom7)
>>     and num_search.seq = 1 );
>> into this table
>> CREATE TABLE public.pipe
>>   id integer,
>>   line geometry,
>>   face_id integer,
>>   branch_point geometry,
>>   branch integer,
>>   up geometry,
>>   up_done integer,
>>   down geometry,
>>   down_done integer,
>>   right_ geometry,
>>   right_done integer,
>>   left_ geometry,
>>   left_done integer
>> WITH (
>>   OIDS=FALSE
>> ALTER TABLE public.pipe
>>   OWNER TO postgres;
>> -- Trigger: branch on public.pipe
>> -- DROP TRIGGER branch ON public.pipe;
>> CREATE TRIGGER branch
>>   AFTER INSERT
>>   ON public.pipe
>>   FOR EACH ROW
>>   EXECUTE PROCEDURE public.branch_point();
>> The line column and the id column are inserted but the down column
>> remains null.
>> It’s and after insert trigger so I don’t think the trigger is stopping
>> the column down insert.
>> Any help would be appreciated.
>> Bob
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121218/e1a45645/attachment.html>
