[postgis-users] PostGIS 2.0 instalation problem
Paragon Corporation
lr at pcorp.us
Tue Dec 18 15:48:27 PST 2012
Willy,
when you say compressed postgis file -- you mean the one on this page?
http://www.postgis.org/download/windows/#windbinaries
I unfortunately don't have a windows xp machine readily handy to test with.
I haven't tried upgrading my test to 9.1.7 to rule that out as an issue so
I'll give that a try.
This issue is usually caused by libxml2-2.dll incompatibilities. Though I
gather you are using the one packaged with PostGIS since it looks like the
postgres one isu using libxml2.dll
Have you been running PostGIS 2 or 1.5 on your windows xp successfully in
past
Thanks,
Regina
http://www.postgis.us
_____
From: Willy-Bas Loos [mailto:willybas at gmail.com]
Sent: Tuesday, December 18, 2012 11:30 AM
To: PostGIS Users Discussion; Paragon Corporation
Subject: Re: [postgis-users] PostGIS 2.0 instalation problem
I have the same problem.
I installed postgres on an XP PC, which worked fine. (PostgreSQL 9.1.7,
compiled by Visual C++ build 1500, 32-bit)
Then I used the StackBuilder to install PostGIS 2.
Upon creating the extension, i get the error "ERROR: could not load library
"C:/Program Files/PostgreSQL/9.1/lib/postgis-2.0.dll": unknown error 998"
The same happens when executing the sql "create extension postgis;"
I tried pasting the contents from the bin folder from the compressed postgis
installation file into ../9.1/bin/, but to no avail.
I used Depends.exe to diagnose, like Paragon suggested.
I included the dwi-file as an attachment.
Is there anything i can do?
Cheers,
WBL
On Sat, May 19, 2012 at 2:50 AM, wobo <mcwobo at hotmail.com> wrote:
So, I've been trying to install PostGIS 2.0 over and over again on several
different Windows XP computers, but didn't succeed in getting it up and
running. So I ended up borrowing my brother's Windows 7 pc, using the exact
same download (postgreSQL + postgis using stackbuilder) which took me about
5 minutes to succesfully install the whole thing.
I have no clue why it doesn't work on my XP. More exactly, why it can't find
the correctly located postgis-2.0.dll-file. But at least I'll be able to
test and recap the 'PostGIS in Action' on Windows 7 from now on.
Many thanks for suggesting and helping anyway.
View this message in context:
http://postgis.17.n6.nabble.com/PostGIS-2-0-instalation-problem-tp4624902p49
93596.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
"Quality comes from focus and clarity of purpose" -- Mark Shuttleworth
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121218/c15a4193/attachment.html>
