[postgis-users] Intersection testing with one-to-many relationships
Nicolas Ribot nicolas.ribot at gmail.com
Mon Dec 24 07:50:27 PST 2012
:) Merci.
Bonnes fetes à vous aussi !
(by the way, quite challenging to also answer the question in one SQL
query: are the turnpoints visited in the right order...)
Nicolas
On 24 December 2012 16:48, Tom Payne <tom at tompayne.org> wrote:
> That's awesome Nicolas.
> Many thanks and bonnes fêtes !
> Tom
> On 24 December 2012 15:30, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
>> (with proper indices, I'm confident this kind of query would be fast
>> enough for your target size)
>> On 24 December 2012 15:29, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
>>> Hi,
>>> There must be a simpler solution than the one provided, but can't see it
>>> right now.
>>> Maybe using windows functions...
>>> Anyway...:
>>> Your 2 questions are the same: for the first one, you will add a WHERE
>>> clause defining the task id you want results for.
>>> The following query is using Common Table Expression (CTE) with WITH
>>> construct, easier to read and write than subqueries.
>>> The first "tasks" query just gives the number of turnpoints per task. It
>>> will be used to filter out flights that do not intersect ALL turnpoints for
>>> a task.
>>> The second "inter" query performs the actual intersection and count the
>>> number of intersected turnpoints for a flight-task pair
>>> Finally, the outer query makes a join between the 2 first CTE tables and
>>> filters rows to keep only flights intersecting ALL turnpoints.
>>> with tasks as (
>>> select t.id, count(tu.id) as num_turnpoint
>>>  from task t, turnpoint tu
>>> where t.id = tu.task_id
>>>  group by t.id
>>> order by t.id
>>> ), inter as (
>>> select  t.id as taskid, f.id as flightid, count(p.id) as cnt
>>>  from tasks t, flight f, turnpoint p
>>> where t.id = p.task_id
>>>  and st_intersects(f.geometry, p.geometry)
>>> group by t.id, f.id
>>> ) select i.*
>>> from inter i, tasks t
>>> where i.cnt = t.num_turnpoint
>>> and t.id = i.taskid;
>>> Nicolas
>>> On 24 December 2012 13:17, Tom Payne <twpayne at gmail.com> wrote:
>>>> Hi,
>>>> tl;dr How to select rows that intersect _all_ geometries defined in a
>>>> one-to-many relationship?
>>>> I'm using PostGIS as the core of a new system for scoring paragliding
>>>> competitions. In such a competition, a task is defined by sequence of
>>>> turnpoints (polygons) that must be visited in order. The pilot submits a
>>>> GPS trace (linestring) as evidence. I'm trying to write a PostGIS query
>>>> that returns all GPS traces that intersect all turnpoints in a given task.
>>>> I've spent time Googling, but this is beyond my current PostGIS/SQL
>>>> abilities.
>>>> My schema looks like:
>>>> -- a task has many turnpoints
>>>> CREATE TABLE task (
>>>> id INTEGER NOT NULL,
>>>>  PRIMARY KEY (id)
>>>> -- a turnpoint belongs to a task and has a geometry
>>>> CREATE TABLE turnpoint (
>>>> task_id INTEGER,
>>>> seq INTEGER NOT NULL, -- index within its task
>>>>  geom geometry(POLYGON,-1) NOT NULL,
>>>> PRIMARY KEY (id),
>>>> UNIQUE (task_id, seq),
>>>>  FOREIGN KEY(task_id) REFERENCES task (id)
>>>> -- a flight has a geometry
>>>> CREATE TABLE flight (
>>>>  geom geometry(LINESTRING,-1) NOT NULL,
>>>> PRIMARY KEY (id)
>>>> What I want is:
>>>> (1) for a given task, return all flight.ids that intersect all of that
>>>> task's turnpoints' geoms; intersection tests can be approximate
>>>> (i.e.intersecting with && is sufficient)
>>>> (2) a list of (task.id, flight.id) pairs where the flight's geom
>>>> intersects all of the task's turnpoints' geoms (intersecting with && is
>>>> sufficient)
>>>> I'm a bit stuck on how to achieve the above. If I use ST_Collect to
>>>> combine all the turnpoints of a single task, and then do the intersection
>>>> test with ST_Intersects then I'll select all flights that intersect ANY of
>>>> the task's turnpoints; not all flights that intersect ALL of the task's
>>>> turnpoints.
>>>> If it is necessary to change the schema (e.g. to represent a task's
>>>> turnpoints as an array of geometries rather than a one-to-many
>>>> relationship) then that's fine.
>>>> Many thanks for any help or pointers on how to achieve this with
>>>> PostGIS.
>>>> Tom
>>>> P.S. Background information, probably not relevant to question:
>>>> - I'd like to use the queries above as an initial filter, the precise
>>>> intersection tests and the checks that the turnpoints are visited in the
>>>> correct order is done in my application
>>>> - Each task typically has 2-5 turnpoints
>>>> - The database will eventually contain thousands of tasks and tens of
>>>> thousands of flights, I plan to make it possible to do query (2) above
>>>> incrementally
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121224/6ab26745/attachment.html>
