[postgis-users] Using PostGIS for latitude & longitude
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Dec 24 13:28:46 PST 2012
Also, be aware that PostGIS expects coordinates in X-Y order which means
for need to enter lat, lon as (long, lat) to correspond to (X, Y).
-Steve
PS: Merry Christmas Brent and everyone else!
On 12/24/2012 3:54 PM, pcreso at pcreso.com wrote:
> Hi Neville,
> Merry Christmas (it already is here in NZ :-)
> You are passing a string - 'POINT(33.911404 -116.768347)' - not a
> geometry in your query hence the error message that ST_SetSRID() doesn't
> know what the first parameter is
> Instead of:
> select state from zipcode where DISTANCE(column2,
> ST_SetSRID('POINT(33.911404 -116.768347)', 2163)) < 8000;
> try:
> ST_SetSRID(ST_MAKEPOINT(33.911404 -116.768347), 2163)) < 8000;
> Cheers,
> Brent
> --- On *Tue, 12/25/12, nevillekb /<nevillekb at gmail.com>/* wrote:
> From: nevillekb <nevillekb at gmail.com>
> Subject: Re: [postgis-users] Using PostGIS for latitude & longitude
> To: postgis-users at postgis.refractions.net
> Date: Tuesday, December 25, 2012, 1:32 AM
> Hi,
> So i created a table named zipcode with the following columns
> Id
> State
> Zip
> Latitude
> Longitude
> column1
> column2
> columns named column1 and column2 are the 2 geometry columns i have
> created
> to store the lat and long in 2 formats -SRID 4269 (Lat/Lon) and SRID
> 2163
> (US National Atlas – meters).
> Then i execute the following query to populate both the columns with
> the lat
> and lon data
> UPDATE zipcode SET column1 =
> ST_SetSRID(ST_MakePoint("longitude","latitude"),4269), column2 =
> ST_Transform(ST_SetSRID(ST_MakePoint("longitude","latitude"),4269),
> 2163);
> Everything has worked fine till now, but now when i try to execute the
> following query to show all records that are within 5 miles of a
> given point
> i get an error.
> Query:
> Error Generated:
> WARNING ] select state from zipcode where DISTANCE(column2,
> ERROR: function st_setsrid(unknown, integer) is not unique
> LINE 1: select state from zipcode where DISTANCE(column2,
> ST_SetSRID...
> HINT: Could not choose a best candidate function. You
> might
> need to add explicit type casts.
> Can someone help me out as to where am i going wrong in the above
> query??
> Thanks
> http://postgis.17.n6.nabble.com/Using-PostGIS-for-latitude-longitude-tp5002097p5002125.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
