[postgis-users] raster2pgsql loader error
Andreas Forø Tollefsen
andreasft at gmail.com
Wed Feb 1 01:02:28 PST 2012
Update:
Updated PostGIS, GEOS and GDAL to latest subversions.
Recompiled and installed but no luck.
andreas at andreas-priogrid:/$ /usr/lib/postgresql/9.1/bin/raster2pgsql -s
4326 -I /home/nils/postgis/lspop2008/lspop2008.txt public.lspop2008 >
/home/andreas/lspop2008.sql
Processing 1/1: /home/nils/postgis/lspop2008/lspop2008.txt
raster2pgsql: rt_api.c:4281: rt_raster_set_srid: Assertion `((void *)0) !=
raster' failed.
Aborted
2012/1/31 Andreas Forø Tollefsen <andreasft at gmail.com>
> I now see that the Warning 6 message is always present but the data are
> still converted to sql.
> However, the
> lt-raster2pgsql: rt_api.c:4281: rt_raster_set_srid: Assertion `((void *)0)
> != raster' failed.
> message aborts the conversion.
>> Hi all,
>> Updated to latest subversion and tried the new loader for the first time.
>> However, i recieve the error below.
>> Never seen this error before using raster2pgsql.py script, but
>> apparently, quite some changes have occured since then.
>> andreas at andreas-priogrid:/mnt/pc258/prio_grid/source/access/access_50k/acc_50k$
>> raster2pgsql -s 4326 -I w001001.adf poptest > /home/andreas/poptest1.sql
>> Processing 1/1: w001001.adf
>> Warning 6: A dataset opened by GDALOpenShared should have the same
>> filename (w001001.adf) and description (.)
>> *)0) != raster' failed.
>> Aborted
>> Any ideas?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120201/624c5e64/attachment.html>
