[postgis-users] Problem building postgis-2.0.0alpha3
Paul Ramsey
pramsey at opengeo.org
Wed Feb 1 12:05:17 PST 2012
Willing to bet you have an old version of GEOS hiding on your system
somewhere. Run 'locate libgeos.so'
P.
On Wed, Feb 1, 2012 at 11:40 AM, Brian Wilson <brian at wildsong.biz> wrote:
> I am stuck trying to build alpha3... I am trying to build from the SVN repo
> (yes, I did an update this morning) and also just tried the tarball alpha3
> I wanted to try it out before our local open source GIS meeting tonight so I
> could give an update.
> I am getting this in the loader directory
> /bin/bash ../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
> -Wmissing-prototypes shpopen.o dbfopen.o getopt.o shp2pgsql-core.o
> shpcommon.o shp2pgsql-cli.o safileio.o ../liblwgeom/liblwgeom.la -o
> shp2pgsql -lc
> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes shpopen.o
> dbfopen.o getopt.o shp2pgsql-core.o shpcommon.o shp2pgsql-cli.o safileio.o
> -o .libs/shp2pgsql ../liblwgeom/.libs/liblwgeom.so -lc
> ../liblwgeom/.libs/liblwgeom.so: undefined reference to
> `GEOSGeom_extractUniquePoints'
> `GEOSGeom_createEmptyPolygon'
> ../liblwgeom/.libs/liblwgeom.so: undefined reference to `GEOSSharedPaths'
> ../liblwgeom/.libs/liblwgeom.so: undefined reference to `GEOSSnap'
> ../liblwgeom/.libs/liblwgeom.so: undefined reference to `GEOSOffsetCurve'
> ../liblwgeom/.libs/liblwgeom.so: undefined reference to `GEOSUnaryUnion'
> collect2: ld returned 1 exit status
> make: *** [shp2pgsql] Error 1
> I have install geos both from current tarball and svn, same results
> I have done builds on this server of svn from 2.0 svn repository before
> (successfully)
> It looks related to geos. I used this for my configure line
> ./configure --with-pgconfig=/usr/local/pgsql/bin/pg_config
> --with-geosconfig=/usr/local/bin/geos-config --with-jsondir=/usr
> --with-topology --with-raster
> and /usr/local/bin/geos-config --version says "3.3.2"
> Thanks for any suggestions
> Brian Wilson
> Corvallis Oregon
> "My life has been full of terrible misfortunes most of which never
> happened."
> -Michel de Montaigne, essayist (1533-1592)
> postgis-users mailing list
