[postgis-users] raster2pgsql loader error
Sandro Santilli
strk at keybit.net
Thu Feb 2 00:41:39 PST 2012
On Thu, Feb 02, 2012 at 09:38:13AM +0100, Andreas Forø Tollefsen wrote:
> Hi people,
> Sorry for spamming, but i simply cant find a solution to this.
> Has no one ever experienced this issue with the raster loader?
Did you seek in the bug tracker ?
If you can't find anything in there please file one, best if you can
also attach the offending file.
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
> Andreas
> 2012/2/1 Andreas Forø Tollefsen <andreasft at gmail.com>
> > Update:
> > Updated PostGIS, GEOS and GDAL to latest subversions.
> > Recompiled and installed but no luck.
> > andreas at andreas-priogrid:/$ /usr/lib/postgresql/9.1/bin/raster2pgsql -s
> > 4326 -I /home/nils/postgis/lspop2008/lspop2008.txt public.lspop2008 >
> > /home/andreas/lspop2008.sql
> > Processing 1/1: /home/nils/postgis/lspop2008/lspop2008.txt
> > raster2pgsql: rt_api.c:4281: rt_raster_set_srid: Assertion `((void *)0) !=
> > raster' failed.
> > Aborted
> > 2012/1/31 Andreas Forø Tollefsen <andreasft at gmail.com>
> >> I now see that the Warning 6 message is always present but the data are
> >> still converted to sql.
> >> However, the
> >> lt-raster2pgsql: rt_api.c:4281: rt_raster_set_srid: Assertion `((void
> >> *)0) != raster' failed.
> >> message aborts the conversion.
> >>> Hi all,
> >>> Updated to latest subversion and tried the new loader for the first time.
> >>> However, i recieve the error below.
> >>> Never seen this error before using raster2pgsql.py script, but
> >>> apparently, quite some changes have occured since then.
> >>> andreas at andreas-priogrid:/mnt/pc258/prio_grid/source/access/access_50k/acc_50k$
> >>> raster2pgsql -s 4326 -I w001001.adf poptest > /home/andreas/poptest1.sql
> >>> Processing 1/1: w001001.adf
> >>> Warning 6: A dataset opened by GDALOpenShared should have the same
> >>> filename (w001001.adf) and description (.)
> >>> Aborted
> >>> Any ideas?
> postgis-users mailing list
