[postgis-users] enforce_dims_geom change between 1.3.3 and 1.4.0?
Paul Ramsey pramsey at opengeo.org
Fri Feb 3 13:46:53 PST 2012
Crazily, we ended up with a situation for a while where the input
checks were looser than the output checks, or could be depending on
the output format you used. I hope we fixed it in later minor
releases, try a later 1.4 release.
P.
On Fri, Feb 3, 2012 at 1:39 PM, Brian Peschel <brianp at occinc.com> wrote:
> I have this geometric is a 1.3.3 PostGIS enabled database:
>  st_npoints |                                 st_astext
>          3 | POLYGON((-97.288445 39.566748,-97.288188 39.566749,-97.288445
> 39.566748))
> I used pg_dump to move this to a 1.4.0 PostGIS enabled database.  And I get
> this:
>  st_npoints
>          3
> for the number of point, but trying to see the geom
> ERROR:  geometry requires more points
> I don't see anything else in my psotgres logs.
> Any ideas?
> - Brian
> postgis-users mailing list
