[postgis-users] Rv: Postgis for Postgres 64 bits
Paragon Corporation lr at pcorp.us
Sat Feb 4 13:43:38 PST 2012
> "First thing 1000x1000 blocks is too big.  If you are going
> to be doing a lot of ST_Value calls, you probably want to
> chunk your tiles to 100x100 or below.
> ST_Value currently requires doing a memcopy for each call so
> the bigger your tiles the more memcopying it will have to do.
> On top of that the bigger your tiles, the less useful
> ST_Intersects is.  Its kind of the same issue with big
> geometries -- like if you stuffed all of africa in one
> record, and then were searching for a city in Africa, the
> ST_Intersects will not be that useful."
> Thanks for this. I did do a few tests. This is what I got:
> Tile Size	Time
> 2000		350873ms
> 1000		235415
> 500		288298
> 300		234895
> 200		231374
> I guess I was concerned that at 200x200 the images were split
> across 3344 rows as opposed to the 176 of the 1000x1000.  I
> am learning here, so I will give 100x100 a go (tomorrow) - I
> just worry about when I need to put the images back together
> (images will be uploaded as tiles and then the originals -
> model outputs - will be deleted). The geometry is composed of
> 100 points (this is for testing only - final configuration
> has yet to be determined) -  I figured it would be faster if
> they were all on the same tile, but may be not?
> Thanks
> Darrel
Bborie probably has more info on this since he's working it and can
hopefully chime in.  Right now the ST_Union you'd use in the db
is not very efficient since its using plpgsql. Doing it with the
gdal_translate is a lot faster and you can do basic where
conditions with that like where file_name='...'.
 In 2.0 ST_Union will be done mostly in C so should be faster.
As far as reconstituting, yes and no.  If your tiles are smaller and you
don't need the full tile,
doing clip operations and union subset that covers a geometric region will
be faster again because of the whole memcopy issue.
However if you need to export the tile -- reconsitute the original, then you
are right a bigger tile would be better, though you may
want to try gdal_translate as that I think is much more efficient for
export.
http://www.postgis.org/documentation/manual-svn/RT_FAQ.html#id2997931
A lot fo these performance issues we'll be dealing with in the 2.1 release,
but for 2.0, we are just focussing on functionality and stability.
Hope that helps,
Regina
