[postgis-users] Query to select features that are parallel and perpendicular
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Feb 6 05:48:11 PST 2012
As Sandro suggested, you can use ST_Azimuth.
I tried on myself and came up which a result, there might be a shorter way.
First, I created a view with the azimuth:
CREATE OR REPLACE VIEW azimuth_view AS
SELECT
id,ST_Azimuth(ST_PointN(wkb_geometry,1),ST_PointN(wkb_geometry,2))*180/pi()
AS azimuth FROM mytable;
This supposes you have only 1 segment on each line (of course!)
Then, I test the difference between the azimuth and I give all parallels
combinations with a given tolerance:
CREATE OR REPLACE VIEW parallel_view AS
SELECT A1.id, A2.id AS parallel
FROM azimuth_view A1, azimuth_view A2
WHERE A1.id != A2.id
AND (abs(A1.azimuth-A2.azimuth) <= tolerance
OR abs(A1.azimuth-A2.azimuth)-360 <= tolerance
OR abs(A1.azimuth-A2.azimuth)+360 <= tolerance );
You can do similar for orthogonal lines then.
PS: I tried with modulo but it does not accept double precision, only
integer. Depending on wanted tolerance, this might not be enough!
Cheers,
Denis
On 02/06/2012 12:45 PM, Sindile Bidla wrote:
> Anyone who can offer advice on on building a query to accomplish the
> following within the same line feature - roads:
> 1. create a new table or view of all line features that are parallel
> to a selected line feature within the same line feature
> 2. create a new table or view of all line features that
> are perpendicular to a selected line feature within the same line feature
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120206/4be3cfbb/attachment.html>
