[postgis-users] Installing a fully functional PostGIS 2.0 on
Ing. Ramon Resendiz
rresendiz at globaltrack.com.mx
Tue Feb 7 08:59:09 PST 2012
OK.
Here is an exmaple about ld.so.conf file:
ld.so.conf.d:
/usr/lib64/pgsql
/usr/local/geos-3.3.1/lib
/usr/local/proj-4.7.0/lib
For this examples the GEOS library directory and PROJ library directory must
be added to the ld.so.conf file in order to be used in the compilation for
POSTGIS.
I hope this can be useful for you.
Best regards,
RR
-----Mensaje original-----
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de THX1138
Enviado el: martes, 07 de febrero de 2012 10:55 a.m.
Para: postgis-users at postgis.refractions.net
Asunto: Re: [postgis-users] Installing a fully functional PostGIS 2.0 on
Can you post an example of what you mean? I didn't quite understand that.
View this message in context:
http://postgis.17.n6.nabble.com/Installing-a-fully-functional-PostGIS-2-0-on
-Ubuntu-Linux-GEOS-GDAL-issues-tp3566227p4373173.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
