[postgis-users] NoData Constraint
Bborie Park
bkpark at ucdavis.edu
Tue Feb 7 09:37:05 PST 2012
Hey David,
No. It isn't a problem per-se. Some would say that it is a problem
since the ideal is that all rasters in a table have the same raster and
band metadata. Personally, having the NODATA value be different across
different rasters in a table isn't significant as it will NOT affect any
raster operations done on any subset or all rows of the table.
-bborie
On 02/07/2012 07:55 AM, David Quinn wrote:
> When loading a raster into my database I get the following message:
> PL/pgSQL function "addrasterconstraints" line 49 at RETURN
> WARNING: Unable to add constraint: 'nodata_values'. Skipping
> CONTEXT: PL/pgSQL function "addrasterconstraints" line 49 at RETURN
> All other messages seem fine. Is it a problem that the NoData constraint is
> not added? Should I be replacing my NoData values in the raster with
> something else before uploading?
> Thanks,
> David
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
