[postgis-users] ST_Intersects(geom, geom) Memory issue
Andreas Forø Tollefsen andreasft at gmail.com
Thu Feb 9 05:56:39 PST 2012
Yes,
I will test this as soon as I am done running a couple of my queries.
Andreas
2012/2/9 Sandro Santilli <strk at keybit.net>:
> Thanks Andreas.
> Could I ask you to also try further filtering your inputs so to avoid
> point geometries as a whole ? It'd help further debugging the issue.
> It would take adding something like this:
>  AND ST_Dimension(p.cell) != 0 AND ST_Dimension(p.geom) != 0
> --strk;
> On Wed, Feb 08, 2012 at 04:55:08PM +0100, Andreas Forř Tollefsen wrote:
>> I tested the query again and identified which commit of revisions
>> introduced the problem.
>> Until revision 8876 the query works fine.
>> After revision 8877 the query leaks memory and eats up all of the
>> servers memory in a couple of minutes.
>> Tested:
>> 8096 OK
>> 8796 OK
>> 8866 OK
>> 8876 OK
>> 8877 NOT OK
>> 8886 NOT OK
>> 8896 NOT OK
>> 8996 NOT OK
>> 9096 NOT OK
>> Again the query was simply:
>> SELECT a.gid, g.startyear, g.endyear, g.cowgroup, a.gridyear INTO geoepr_cell
>> FROM priogridall a, priogrid p, geoepreth2 g WHERE a.gid = p.gid AND
>> a.gridyear = 1946 AND a.gwcode = g.cowcode AND ST_Intersects(p.cell,
>> g.geom)
>> AND g.startyear <= 1946 AND g.endyear >= 1946 GROUP BY a.gid,
>> g.startyear, g.endyear, g.cowgroup, a.gridyear ORDER BY gid ;
>> Would be great if you could look into this.
>> Best,
>> Andreas
>> 2012/2/4 Andreas Forř Tollefsen <andreasft at gmail.com>:
>> > I created a new clean db and installed latest rev. Then loaded my tables and
>> > ran the query with the same error and postgres server crash.
>> > Any suggestions on how i can solve this? As for now i am using rev 8292 and
>> > then the query and my raster summaries work.
>  ,------o-.
>  |   __/  |    Thank you for PostGIS-2.0 Topology !
>  |  / 2.0 |    http://www.pledgebank.com/postgistopology
>  `-o------'
