[postgis-users] Question about using ST_Transform()
David Quinn
daithiquinn at gmail.com
Thu Feb 9 07:45:03 PST 2012
Hello All,
I'm trying to understand how to use ST_Transform() on a query. When I have
everything in the same projection (in this case Albers Equal Area Conic) my
query returns the correct result:
SELECT
SUM((stats).sum)
FROM (
select
ST_SummaryStats(ST_Clip(r.rast, 1, p.geom, NULL, TRUE)) as stats
FROM
ny_albers as r,
cities_albers as p
WHERE
p.name = 'new_york'
AND
ST_Intersects(r.rast, p.geom)
) as foo;
If I use a table with polygons in a different projection (in this case Web
Mercator), I do not get any values returned:
SELECT
SUM((stats).sum)
FROM (
select
ST_SummaryStats(ST_Clip(r.rast, 1, ST_Transform(p.geom,102003),
FROM
ny_albers as r,
cities_webMercator as p
WHERE
p.name = 'new_york'
AND
ST_Intersects(r.rast, ST_Transform(p.geom,102003))
) as foo;
I added the projection SRID:102003 using the following lines:
INSERT into
spatial_ref_sys (
srid,
auth_name,
auth_srid,
srtext,
proj4text
values (
102003, -- I changed this line as it was originally 9102003 which did
not satisfy the constraints
'esri',
102003,
'PROJCS["USA_Contiguous_Albers_Equal_Area_Conic",GEOGCS["GCS_North_American_1983",DATUM["North_American_Datum_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["longitude_of_center",-96],PARAMETER["Standard_Parallel_1",29.5],PARAMETER["Standard_Parallel_2",45.5],PARAMETER["latitude_of_center",37.5],UNIT["Meter",1],AUTHORITY["EPSG","102003"]]',
'+proj=aea +lat_1=29.5 +lat_2=45.5 +lat_0=37.5 +lon_0=-96 +x_0=0
+y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs ');
I had some problems when I tried to add this projection from
http://spatialreference.org/ref/esri/102003/postgis/
The names and values of srtext, and proj4text were reversed, and the SRID
seemed incorrect so I changed it. I don't know if this is related to my
question above, but I thought it worth mentioning. I did import the raster
and polygon using this SRID on the query that worked.
Thank you,
David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120209/bf8a9f01/attachment.html>
