[postgis-users] Postgis topology issue
francescoboccacci at libero.it
Thu Feb 9 08:01:15 PST 2012
Hi all,
i'm "playing" with Postgis 2.0 Topology function and i like it.. but i receive
this error:
********** Error **********
ERROR: SQL/MM Spatial exception - point not on edge
SQL state: P0001
Context: PL/pgSQL function "topogeo_addpoint" line 66 at assignment
PL/pgSQL function "topogeo_addlinestring" line 111 at assignment
SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select topology.
TopoGeo_addLinestring(atopology, rec.geom, tolerance) as x ) as foo"
PL/pgSQL function "topogeo_addpolygon" line 23 at assignment
SQL statement "INSERT INTO sample1.relation(topogeo_id, layer_id,
element_type, element_id) SELECT 5, 1, 3, topogeo_addPolygon('sample1',
'0103000000010000000A00000000000080AB6829413789412068EB284137894160A9682941000000002BEB2841C976BEDFA5682941000000C0C0EA2841C976BE1FA4682941378941A08AEA28410000008049682941378941A08DEA2841C976BE5F4B68294100000080C5EA2841000000804B68294100000080C7EA2841000000004F682941000000402FEB28410000000051682941000000406BEB284100000080AB6829413789412068EB2841'::
geometry, 0);"
PL/pgSQL function "totopogeom" line 125 at EXECUTE statement
these are my query that are "copy and paste " from
http://postgis.refractions.net/pipermail/postgis-users/2012-January/032169.
html
--Create new togology ---
SELECT CreateTopology('sample1');
--Add topoGeomColumn---
SELECT AddTopoGeometryColumn('sample1',
'public', 'small_polygon', 'topogeom',
'POLYGON');
UPDATE small_polygon SET topogeom = toTopoGeom(the_geom, 'sample1',1);
Do you have any suggestion? maybe i used a a wrong geometry..
Thanks
Francesco
