[postgis-users] error: conversion to non-scalar type requested
Tam, Edison (IS)
Edison.Tam at ngc.com
Thu Feb 9 13:13:17 PST 2012
I try to build the PostGIS from source. I followed the instruction until step 13: Compiling LibXML2. For some reason the following error shows up:
testThreads.c: In function 'main':
testThreads.c:110:6: error: conversion to non-scalar type requested
However, if I compile it under Cygwin, it would not happen. It only appears in MinGW.
Does anyone has any ideas?
Thank you!
Edison
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120209/49f4f0f1/attachment.html>
