[postgis-users] Trouble seeinglisting tables
pcreso at pcreso.com pcreso at pcreso.com
Mon Feb 13 14:06:06 PST 2012
Nothing obvious that I can see.
psql -d <db>
\d                  # should list the tables
\d mytable     # should list the structure of the table "mytable"
select * from mytable;  # should list the contents of mytable.
If you can post the outputs from these commands (the text before the "#") we can probably offer more informed advice.
Cheers
  Brent Wood
--- On Tue, 2/14/12, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
Subject: [postgis-users] Trouble seeinglisting tables
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Tuesday, February 14, 2012, 9:58 AM
I am having trouble on a pretty basic level.  I loaded a
couple shapefiles into PostGIS.  I can see that they successfully loaded when I
use pgAdmin.  But when I go to command line, I have trouble.  I can do a \d
command and see the tables exist in the database.  But if I do a select * from
mytable; I get an errer, “relation “mytable” does not exist.
What am I doing wrong here?
-----Inline Attachment Follows-----
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120213/34793708/attachment.html>
