[postgis-users] what is the default password of Postgres user in POSTGIS 2.0
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Feb 14 08:18:07 PST 2012
This is kind of strange...
Can you execute any other command located in this same folder?
What is the extension of the file raster2pgsql? What if you add it at the end?
On which OS are you operating?
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Zelio Fernandes
> Sent: Tuesday, February 14, 2012 11:11 AM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] what is the default password of Postgres user in
> POSTGIS 2.0
> I have POSTGIS 2.0 alpha5 build and it is located in the same folder you
> mentioned that is in usr/lib/postgres9.1/bin/
> i have first navigated to usr/lib/postgres9.1/bin/ and then executed raster2pgsql
> -G and it gave error message as command not found.
> View this message in context: http://postgis.17.n6.nabble.com/what-is-the-
> default-password-of-Postgres-user-in-POSTGIS-2-0-tp4468052p4469300.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
