[postgis-users] Landtype minus parcels ?
Brian Hamlin
maplabs at light42.com
Tue Feb 14 11:42:05 PST 2012
Hi All-
maybe I am missing an easier solution.. I would like to subtract
the sum of all parcels in a county, from a "landtypes" table for the
same county.
Landtypes are non-overlapping areas with a category.. Although this
is straightforward to describe, I am writing things that take a long
time, and are not simple.
note that I use python as much or more than SQL. Most jobs are in
python using psycopg2 to execute the SQL. I have no problem with
looping in python to get a desired result, but if there is something
straightforward in SQL than of course the database can do a better
job of optimizing..
The best I have so far is as follows:
in python, loop through all landtype records
for that landtype record, find all parcels that intersect it
ST_UNION() those parcels
subtract the ST_UNION'd result from that landtype record, and
store it
this is how I wrote it -- suggestions and improvements requested
(yes I left the DISTINCT ON in there.. I was getting multiple,
identical rows back instead of one row ??)
SELECT distinct on (tgeom)
st_difference(
l.wkb_geometry,
(select st_union(p.wkb_geometry )
from
big_landtypes l,
small_parcels p
where st_intersects(
l.wkb_geometry, p.wkb_geometry) AND
l.pkey = 1)
) tgeom
FROM
big_landtypes l,
small_parcels p
WHERE
l.pkey = 1
ORDER BY
tgeom;
Unique (cost=3044213.34..3047941.15 rows=1 width=9069) (actual
time=190578.880..190865.979 rows=1 loops=1)
InitPlan 1 (returns $1)
-> Aggregate (cost=29.92..29.93 rows=1 width=3203) (actual
time=5.276..5.277 rows=1 loops=1)
-> Nested Loop (cost=0.00..29.83 rows=35 width=3203)
(actual time=0.765..2.317 rows=11 loops=1)
Join Filter: _st_intersects(l.wkb_geometry,
p.wkb_geometry)
-> Index Scan using big_landtypes_pkey on
big_landtypes l (cost=0.00..8.27 rows=1 width=9069) (actual
time=0.004..0.006 rows=1 loops=1)
Index Cond: (pkey = 1)
-> Index Scan using small_parcels_geom_idx on
small_parcels p (cost=0.00..20.51 rows=4 width=3203) (actual
time=0.075..0.649 rows=55 loops=1)
Index Cond: (l.wkb_geometry && wkb_geometry)
-> Sort (cost=3044183.42..3046047.32 rows=745562 width=9069)
(actual time=190578.878..190616.465 rows=745808 loops=1)
Sort Key: (st_difference(l.wkb_geometry, $1))
Sort Method: quicksort Memory: 59536kB
-> Nested Loop (cost=0.00..74035.41 rows=745562
width=9069) (actual time=5.732..189597.837 rows=745808 loops=1)
time=0.011..0.015 rows=1 loops=1)
-> Seq Scan on small_parcels p (cost=0.00..64707.62
rows=745562 width=0) (actual time=0.004..491.980 rows=745808 loops=1)
