[postgis-users] ST_AsJpeg
    Bborie Park
    bkpark at ucdavis.edu
    Tue Feb 14 15:03:10 PST 2012
ST_AsKML(geometry) would be returning XML so suffers no binary issues.
-bborie
On 02/14/2012 02:53 PM, Pierre Racine wrote:
> Curious that the question was never raised for ST_AsKML(geometry)...
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of Paragon Corporation
>> Sent: Tuesday, February 14, 2012 5:43 PM
>> To: 'PostGIS Users Discussion'
>> Subject: Re: [postgis-users] ST_AsJpeg
>> Here it is in the docs now:
>> http://postgis.refractions.net/documentation/manual-
>> svn/using_raster.xml.html#RasterOutput_PSQL
>> ________________________________
>> users-bounces at postgis.refractions.net] On Behalf Of Joan
>> 	Sent: Tuesday, February 14, 2012 4:23 PM
>> 	To: PostGIS Users Discussion
>> 	The last two solutions result in a black square, which I think is the tile.
>> But it's a good start. I will have to look more into that.
>> 	Regina, I have tried using \g to out put to a file but the file is corrupted.
>> 	I appreciate the help.
>> 	Joan
>> 	On 14 February 2012 21:27, Paragon Corporation<lr at pcorp.us>  wrote:
>> 		We have this documented in the docs.
>> 		http://www.postgis.org/documentation/manual-
>> svn/using_raster.xml.html#RT_Raster_Applications
>> 		There is an example for doing it with PHP, .NET, Java, and
>> PLPython
>> 		Sorry don't have one for psql only.  Haven't tried using psql for
>> outputting
>> 		files.
>> 		Regina
>> 		http://www.postgis.us
>> 		>  [mailto:postgis-users-bounces at postgis.refractions.net] On
>> 		>  Behalf Of Pierre Racine
>> 		>  Sent: Tuesday, February 14, 2012 11:05 AM
>> 		>  So you might have to write a script connecting to PostgreSQL
>> 		>  and writing the file for you. See an example in:
>> 		>  http://www.bostongis.com/blog/index.php?/archives/175-
>> Minimali
>> 		>  st-Web-based-PHP-PostGIS-2.0-Spatial-GeometryRaster-
>> Viewer.html
>> 		>  Pierre
>> 		>  >  [mailto:postgis-users- bounces at postgis.refractions.net] On
>> 		>  Behalf Of
>> 		>  >  Joan
>> 		>  >  Sent: Tuesday, February 14, 2012 10:10 AM
>> 		>  >  Yes, I want to create a jpeg/tiff file. I am new to
>> 		>  cursors, how would
>> 		>  >  that work in a query.
>> 		>  >  On 14 February 2012 15:39, Pierre Racine
>> 		>  <Pierre.Racine at sbf.ulaval.ca>  wrote:
>> 		>  >      Thanks,
>> 		>  >      Do you see any way to make the file directly readable
>> 		>  (without having
>> 		>  >  to edit it)?
>> 		>  >      Pierre
>> 		>  >  [mailto:postgis-
>> 		>  >  users-
>> 		>  >      >  bounces at postgis.refractions.net] On Behalf Of Sandro
>> Santilli
>> 		>  >      >  Sent: Tuesday, February 14, 2012 9:28 AM
>> 		>  >      >  On Tue, Feb 14, 2012 at 09:22:21AM -0500, Pierre
>> Racine wrote:
>> 		>  >      >  >  Yes. You want to write the file directly to the
>> filesystem?
>> 		>  >  Sandro wrote
>> 		>  >      >  something in the list about this recently but I can't
>> 		>  find it. Sandro?
>> 		>  >  Robe?
>> 		>  >      >  I ended up binary-editing the result afterwards.
>> 		>  >      >  Anyway, first step is declaring a binary cursor,
>> 		>  redirecting output
>> 		>  >  to a file and
>> 		>  >      >  calling the function.
>> 		>  >      >  For the binary editing, I looked at another file with
>> 		>  my expected
>> 		>  >  format to tell
>> 		>  >      >  where it started (human eye pattern matching).
>> 		>  >      >  >  You can also use gdal_translate...
>> 		>  >      >  Much better, when it works (it wasn't working for me).
>> 		>  >      >  --strk;
>> 		>  >      >    ,------o-.
>> 		>  >      >    |   __/  |    Delivering high quality PostGIS 2.0 !
>> 		>  >      >    |  / 2.0 |    http://strk.keybit.net
>> 		>  >      >    `-o------'
>> 		>  >      >  postgis-users mailing list
>> 		>  >      >  postgis-users at postgis.refractions.net
>> 		>  >      >  http://postgis.refractions.net/mailman/listinfo/postgis-
>> users
>> users
>> 		>  http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
