[postgis-users] PostGIS Manager QGIS Plugin error
cavallini@faunalia.it cavallini at faunalia.it
Wed Feb 15 23:53:40 PST 2012
Please try the new DB manager plugin and report back.
Thanks.
http://faunalia.it/pc
Sent from mobile, sorry for being short
----- Reply message -----
Da: "Ben Madin" <lists at remoteinformation.com.au>
A: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Oggetto: [postgis-users] PostGIS Manager QGIS Plugin error
Data: gio, feb 16, 2012 08:24
Kevin,
That sounds like a syntax error in the plugin itself. You probably need to contact the maintainer. I can't actually get it to work in QGIS 1.7.3 on OSX 10.6.8
cheers
Ben
On 16/02/2012, at 7:21 AM, Kevin Goulding wrote:I'm just now getting set up with a PostGIS database connected with QGIS.  A few plugins are giving me errors when I try to connect to my database. I am using Mac OS X 10.6.8 and QGIS 1.8.
When I try to connect to my PostGIS database using the "PostGIS Manager" plugin, I receive the following error:“Couldn’t connect to database: missing “=” after “‘” in connection info string”.
Any thoughts?  I will add that I have successfully added PostGIS layers to my project, but now want to start using pgRouting, so need to connect to the database.  I receive the exact same error when attempting to use the "pgRouting Layer" plugin.
Thanks! Kevin
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120216/89c6105f/attachment.html>
