[postgis-users] Bogus unknown geometry error from ST_Transform
Aren Cambre
aren at arencambre.com
Sun Feb 19 07:07:51 PST 2012
I just ran this:
*SELECT ST_AsEWKT(the_geom)*
*FROM gis."gz_2010_48_160_00_500k"*
*LIMIT 1;*
Here's what I get:
*"POLYGON((-94.940569 29.330815,-94.93334 29.329038,-94.930971
29.327708,-94.929679 29.32634,-94.938834 29.320412,-94.946644
29.323065,-94.946988 29.326066,-94.94085 29.330469,-94.940569 29.330815))"*
So it appears that SRID is in fact not embedded?
This PostGIS dataset was imported from a SHP using Quantum GIS's SPIT. SPIT
did not set a value for *the_geom* in *public.geometry_columns*--I believe
it can, but I didn't specify any options to do that.
I added a row for the *the_geom* field using the code recommended in the
PostGIS online instructions:
*INSERT INTO geometry_columns(f_table_catalog, f_table_schema,
f_table_name, f_geometry_column, coord_dimension, srid, "type")*
*SELECT '', 'gis', 'gz_2010_48_160_00_500k', 'the_geom',
ST_CoordDim(the_geom), ST_SRID(the_geom), GeometryType(the_geom)*
*FROM gis.gz_2010_48_160_00_500k LIMIT 1;*
And when I do that, the SRID in the table is *-1*, so yes, I have to
manually change to *4326*.
So maybe ST_Transform doesn't reference the *public.geometry_columns* table
after all? Seems like it ought to if the SRID isn't contained in the
geometry object.
By the way, the original SHP is *EPSG:4269 - NAD83* per Quantum GIS. (Oops,
I was using 4326 previously, but not sure that explains the errors.)
Aren
On Sun, Feb 19, 2012 at 8:54 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> SRID=-1 means that the geometry SRID is unknown or has no SRID. This is
> NOT synonym got 4326.
> Also, every geometry has an SRID embedded in it. If all you did is change
> the value in the public.geometry_columns table then you have NOT changed
> the geometry's SRID and the SRID of the geometry is the only thing that is
> looked at by the ST_* functions.
> -Steve
> On 2/19/2012 3:10 AM, pcreso at pcreso.com wrote:
>> Does this work?
>> *UPDATE gis."gz_2010_48_160_00_500k"*
>> *SET "the_geom_3081" = ST_Transform((ST_Setsrid(the_**geom, 4326),3081);*
>> ie:: is the problem finding the srid from geometry_columns or finding it
>> but ST_Transform() fails even when given the srid?
>> Even if there is a bug, this may work for you until fixed?
>> Brent Wood
>> --- On *Sun, 2/19/12, René Romero Benavides /<ichbinrene at gmail.com>/*
>> wrote:
>> From: René Romero Benavides <ichbinrene at gmail.com>
>> Subject: Re: [postgis-users] Bogus unknown geometry error from
>> ST_Transform
>> To: postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> Date: Sunday, February 19, 2012, 8:37 PM
>> El 18/02/2012 11:29 p.m., Aren Cambre escribió:
>>> ST_Transform is returning a bogus error of*Input geometry has
>>> unknown (-1) SRID*.
>>> Here's the query:
>>> *SET "the_geom_3081" = ST_Transform(the_geom, 3081);*
>>> I said "bogus" because the database's *public.geometry_columns*
>>> table has valid values for these two columns, and neither has SRID
>>> of -1:
>>> *34281;"''";"gis";"gz_2010_48_**160_00_500k";"the_geom";2;**
>>> 4326;"POLYGON"*
>>> *34276;"''";"gis";"gz_2010_48_**160_00_500k";"the_geom_3081";**
>>> 2;3081;"POLYGON"*
>>> What gives?
>>> Aren
>>> ______________________________**_________________
>>> postgis-users mailing list
>>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net> </mc/compose?to=
>>> postgis-users@**postgis.refractions.net<postgis-users at postgis.refractions.net>
>>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>> I thought a SRID of -1 was a synonym for the default one (4326). But
>> don't take my word for it, I'm beginning with postgis.
>> http://sharingtechknowledge.**blogspot.com/<http://sharingtechknowledge.blogspot.com/>
>> -----Inline Attachment Follows-----
>> </mc/compose?to=postgis-users@**postgis.refractions.net<postgis-users at postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120219/6d6aae3a/attachment.html>
