[postgis-users] Raster displaced when loading or make a new one
    Jose Carlos Martinez
    jomarlla at cgf.upv.es
    Mon Feb 20 04:34:41 PST 2012
Im getting a problem with raster in PostGIS 2.0, r9200.
  POSTGIS="2.0.0alpha6SVN" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
USE_STATS
I have loaded a raster file successfully. The layer is dem1 and the
raster column is rast.
The  when I try to make any new raster from this one, even just a copy
of it:
alter table dem1 add column rast1 raster;
update dem1 set rast1 = rast;
--UPDATE 132
select addrasterconstraints ('dem1','rast1');
I got the new raster 'rast1' displaced.
Dont know what im doing wrong. QGIS and GDAL_translate to png show the
same problem (maybe its no a postgis problem but a gdal problem?):
I uploaded a pdf with the images [1].
PD: Im having similar problems when I try to load a tif raster to PostGIS.
[1]
http://intercambio.upv.es/download.php?id=35c292331b627e462c1d5d92187bf492
The constrains are the same in both:
ra1=# \d dem1
                           Table "public.dem1"
  Column |  Type   |                     Modifiers
  rid    | integer | not null default nextval('dem1_rid_seq'::regclass)
  rast   | raster  |
  rast1  | raster  |
Indexes:
     "dem1_pkey" PRIMARY KEY, btree (rid)
Check constraints:
     "enforce_height_rast" CHECK (st_height(rast) = 100)
     "enforce_height_rast1" CHECK (st_height(rast1) = 100)
     "enforce_max_extent_rast" CHECK (st_coveredby(st_convexhull(rast),
'0103000020E76400000100000005000000C09AA2803CA41A4104D63FE70A795041C09AA2803CA41A4104D63FE776E45041604D51409EFB204104D63FE776E45041604D51409EFB204104D63FE70A795041C09AA2803CA41A4104D63FE70A795041'::geometry))
     "enforce_max_extent_rast1" CHECK
(st_coveredby(st_convexhull(rast1),
     "enforce_nodata_values_rast" CHECK
(_raster_constraint_nodata_values(rast)::numeric(16,10)[] =
'{32767}'::numeric(16,10)[])
     "enforce_nodata_values_rast1" CHECK
(_raster_constraint_nodata_values(rast1)::numeric(16,10)[] =
     "enforce_num_bands_rast" CHECK (st_numbands(rast) = 1)
     "enforce_num_bands_rast1" CHECK (st_numbands(rast1) = 1)
     "enforce_out_db_rast" CHECK (_raster_constraint_out_db(rast) =
'{f}'::boolean[])
     "enforce_out_db_rast1" CHECK (_raster_constraint_out_db(rast1) =
'{f}'::boolean[])
     "enforce_pixel_types_rast" CHECK
(_raster_constraint_pixel_types(rast) = '{16BSI}'::text[])
     "enforce_pixel_types_rast1" CHECK
(_raster_constraint_pixel_types(rast1) = '{16BSI}'::text[])
     "enforce_same_alignment_rast" CHECK (st_samealignment(rast,
'0100000000000000000000594000000000000059C0C09AA2803CA41A4104D63FE776E4504100000000000000000000000000000000E764000001000100'::raster))
     "enforce_same_alignment_rast1" CHECK (st_samealignment(rast1,
'0100000000000000000000594000000000000059C0C09AA280FC781C4104D63FE7EED0504100000000000000000000000000000000E764000001000100'::raster))
     "enforce_scalex_rast" CHECK (st_scalex(rast)::numeric(16,10) =
100::numeric(16,10))
     "enforce_scalex_rast1" CHECK (st_scalex(rast1)::numeric(16,10) =
     "enforce_scaley_rast" CHECK (st_scaley(rast)::numeric(16,10) =
(-100)::numeric(16,10))
     "enforce_scaley_rast1" CHECK (st_scaley(rast1)::numeric(16,10) =
     "enforce_srid_rast" CHECK (st_srid(rast) = 25831)
     "enforce_srid_rast1" CHECK (st_srid(rast1) = 25831)
     "enforce_width_rast" CHECK (st_width(rast) = 100)
     "enforce_width_rast1" CHECK (st_width(rast1) = 100)
Best,
Jose
