[postgis-users] problem with the_geom returned by ST_Line_Substring
Sandro Santilli
strk at keybit.net
Tue Feb 21 07:08:44 PST 2012
Sounds like a bad bug, can you reproduce with a small
(like 2 or 3 vertices) input ? Would you file a ticket
for it on http://trac.osgeo.org/postgis/ ?
--strk;
On Tue, Feb 21, 2012 at 09:49:22AM -0500, Worth Lutz wrote:
> Postgis 1.5.3
> I'm having a problem with the output of ST_Line_Substring().
> Mapserver will not display the results when I replace the original geom with
> the substring. The geometry is there but when trying to look at it I see
> some anomalies. I have noticed that when I look at the results with
> ST_AsText:
> ST_AsText(the_geom) returns:
> MULTILINESTRING((2109131.635 773598.026, ...
> ST_AsText(ST_Line_Substring(the_geom, 0, 0.5)) returns:
> MULTILINESTRING(SRID=2264;(2109131.635 773598.026, ...
> I do not know if that is a clue to the problem.
> Also:
> ST_AsEWKT(the_geom) returns:
> SRID=2264;MULTILINESTRING((2109131.635 773598.026, ...
> ST_AsEWKT(ST_Line_Substring(the_geom, 0, 0.5)) returns:
> SRID=2264;MULTILINESTRING(SRID=2264;(2109131.635 773598.026, ...
> postgis-users mailing list
