[postgis-users] Transform
Bborie Park
bkpark at ucdavis.edu
Tue Feb 21 11:20:08 PST 2012
Steve,
Are you running Windows? If so, I believe there is a known issue with
GDAL not finding the proj.4 DLL. You'll need to set the env variable
PROJSO to the full path to the DLL.
http://trac.osgeo.org/gdal/wiki/ConfigOptions
-bborie
On 02/21/2012 11:06 AM, Stephen Crawford wrote:
> Hi All,
> I'm trying to transform as raster set in this way:
> SELECT rid, observation_date, ST_Transform(rast, 4326) AS rast INTO
> risk_wgs84
> FROM spring_ms
> WHERE observation_date = '2012-02-20';
> I would expect the target table "risk_wgs84" to be in lat/lon, but if I
> run:
> ST_Extent(rast) from risk_wgs84 I get values in meters (same as the
> original table "spring_ms"):
> any ideas?
> Thanks,
> Steve
> Stephen Crawford
> Center for Environmental Informatics
> The Pennsylvania State University
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
