[postgis-users] extra function?
Bborie Park bkpark at ucdavis.edu
Wed Feb 22 14:03:58 PST 2012
There are two sets of _st_summarystats and st_summarystats, one for
single rasters and another for raster tables.
You should only have one _st_summarystats(rast raster, ...) function and
two st_summarystats(rast raster, ...) functions for single rasters.
For raster tables, you should have one _st_summarystats(rastertable
text, rastercolumn text, ...) and two st_summarystats(rastertable text,
rastercolumn text, ...) functions.
There are separate sets of functions for approximate summary stats
(ST_ApproxSummaryStats).
-bborie
On 02/22/2012 01:56 PM, Stephen Crawford wrote:
> _st_summarystats and st_summarystats are listed with the same exact
> arguments. Should this be the case? There are also 7 other
> "st_summarystats" listed, all with different numbers of arguments.
> And now I'm really out the door, back at it tomorrow, many thanks.
> On 2/22/2012 4:48 PM, Bborie Park wrote:
>> Good point. I didn't think about duplicative function declarations,
>> though that shouldn't happen as the function signatures haven't
>> changed in a long time.
>> -bborie
>> On 02/22/2012 01:39 PM, John Callahan wrote:
>>> Steve,
>>> I had a similar issue. If you look at your list of functions (say
>>> through
>>> pgAdmin), you'll probably see multiple instances of that function. If
>>> the
>>> same function is listed more than once, with the same number and type of
>>> arguments, then it will (I think?) report as not unique. In that case, I
>>> manually deleted the duplicate functions, and then added them back.
>>> To add
>>> them back, look inside the rt_postgis.sql (or postgis.sql) file than
>>> comes
>>> with the distribution (I'm using alpha5). you'll see all of the
>>> functions
>>> in there. Just cut and paste the necessary CREATE OR REPLACE statements
>>> for your functions into the Query Tool or psql console window.
>>> - John
>>> John Callahan, Research Scientist
>>> Delaware Geological Survey, University of Delaware
>>> URL: http://www.dgs.udel.edu
>>> On Wed, Feb 22, 2012 at 4:28 PM, Bborie Park<bkpark at ucdavis.edu> wrote:
>>>> Steve,
>>>> I know enough to do my own testing and make the necessary changes.
>>>> Until I
>>>> have the time to do so, the following should work.
>>>> CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
>>>> exclude_nodata_value boolean)
>>>> RETURNS summarystats
>>>> AS $$ SELECT _st_summarystats($1, 1, $2, 1.) $$
>>>> LANGUAGE 'SQL' IMMUTABLE STRICT;
>>>> -bborie
>>>> On 02/22/2012 12:16 PM, Stephen Crawford wrote:
>>>>> Tried running it and get this:
>>>>> "ERROR: function _st_summarystats(raster, integer, boolean,
>>>>> integer) is
>>>>> not unique
>>>>> LINE 3: AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
>>>>> HINT: Could not choose best candidate function. You might need to add
>>>>> explicit type casts"
>>>>> -Steve
>>>>> On 2/22/2012 1:59 PM, Bborie Park wrote:
>>>>>> Interesting. Can you run the following and try again?
>>>>>> If that removes the HINT, I'll make the appropriate changes to the
>>>>>> code.
>>>>>> -bborie
>>>>>> On 02/22/2012 10:48 AM, Stephen Crawford wrote:
>>>>>>> I only tried the casting because of the messages I get, on of
>>>>>>> which is:
>>>>>>> "function _st_summarystats($1, 1, $2, 1) is not unique"
>>>>>>> and
>>>>>>> "HINT: Could not choose best candidate function. You might need
>>>>>>> to add
>>>>>>> Thanks,
>>>>>>> steve
>>>>>>> On 2/22/2012 1:41 PM, Bborie Park wrote:
>>>>>>>> Hey Steve,
>>>>>>>> _st_summarystats is an underlying function that isn't meant for
>>>>>>>> use by
>>>>>>>> end-users. ST_SummaryStats is what you should be using.
>>>>>>>> The example query you provided shouldn't have any issues and
>>>>>>>> shouldn't
>>>>>>>> be creating any of those messages. In your situation, you don't
>>>>>>>> even
>>>>>>>> need the true::boolean.
>>>>>>>> -bborie
>>>>>>>> On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>>>>>>>>> Should I have both _st_summarystats and st_summarystats in my
>>>>>>>>> database?
>>>>>>>>> I get messages like "function not unique" and "could not choose
>>>>>>>>> best
>>>>>>>>> candidate function" when doing this:
>>>>>>>>> SELECT rid, observation_date, ST_SummaryStats(rast::raster,
>>>>>>>>> true::boolean) FROM spring_ms WHERE observation_date =
>>>>>>>>> '2012-02-20';
>>>>>>>>> I expected to get 187 records (one for each tile).
>>>>>>>>> Thanks,
>>>>>>>>> Steve
>>>> Bborie Park
>>>> Programmer
>>>> Center for Vectorborne Diseases
>>>> UC Davis
>>>> 530-752-8380
>>>> ______________________________**_________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
Bborie Park
Programmer
UC Davis
530-752-8380
