[postgis-users] different results for area with different programms
Astrid Emde
astrid.emde at wheregroup.com
Thu Feb 23 08:10:16 PST 2012
Martin,
I think you are right. Paul mentioned that area calculation is done by
PostGIS itself.
Astrid
On Thu, February 23, 2012 4:06 pm, Martin Davis wrote:
> The JTS area algorithm has been tweaked slightly recently, but that's
> not it - I get the same answer with JTS 1.8 (which uses the original
> algorithm).
> I'm guessing PostGIS doesn't use GEOS for area, right?
> Anyway, looks like it's fixed in the latest version.
> On 2/23/2012 7:25 AM, Sandro Santilli wrote:
>> Martin, JTS area calculator changed too recently
>> (the shoelace formula). Could that explain ?
>> BTW, here's what I get with PostGIS 2.0.0alpha7SVN:
>> 9.33616450013379
> postgis-users mailing list postgis-users at postgis.refractions.net
Mit freundlichen Grüßen
Astrid Emde
FOSSGIS Konferenz 2012
20.-22. März 2012 in Dessau
http://www.fossgis.de/konferenz/2012
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
