[postgis-users] topology example
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Fri Feb 24 00:20:13 PST 2012
Thanks.
As I have installed from scratch the upgrade files are useless for me,
right?
(I am getting lost...)
Ticket #1611 has been filled
I'll try to do the loop today and check.
I'll let you know!
On 02/24/2012 09:10 AM, Sandro Santilli wrote:
> On Fri, Feb 24, 2012 at 07:34:54AM +0100, Denis Rouzaud wrote:
>> Hi Sandro,
>> Thanks again.
>> I have a fresh installed for 2 days now.
>> Postgis 2.0 a6 (it is a 7 now)
>> Geos 3.3.2
>> Is this ok?
> Should be, yes.
>> I did not do anything with topology_upgrade.sql, there is nothing
>> written in the installation doc.
> That's a bug in the documentation, could you file it on
> http://trac.osgeo.org please ?
>> What should I do with it?
> The same you do with postgis_upgrade.sql everytime you do upgrade
> from one version to another... load it.
>> Would you perform a loop to update the topogeom field, so one entry at once?
> A loop would indeed be preferrable. I saw a noticable speedup
> when looping from outside the database.
>> Thanks a lot for your valuable help!
> Thank you for your feedback, keep me posted ! :)
> --strk;
>    ,------o-.
>    |   __/  |    Delivering high quality PostGIS 2.0 !
>    |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
>    `-o------'
> postgis-users mailing list
