[postgis-users] topology example
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Feb 28 08:06:10 PST 2012
Hi Sandro,
Thanks a lot for your attention.
I did not had so much time to look deeply into it these two days.
So far, I could not perform make check correctly due to some passwords
problems.
Basically, I have a database in oracle (non spatial) in topobase
(autocad) with pipes. I am migrating the whole thing to use Qgis to
manage the network.
So I collected all the given errors when using toTopoGeom to first
correct the geometry in autocad, then re-importing and re-creating the
topology again.
I don't really understand how the topology is handled in postgis and
what is for example written in the topogeom column.
There is still one main point which I don't understand. Why is there any
control on the topology if there is validateTopology function?
On 02/28/2012 04:31 PM, Sandro Santilli wrote:
> On Fri, Feb 24, 2012 at 04:44:24PM +0100, Denis Rouzaud wrote:
>> Thanks a lot for your time and work!
>> Maybe, everything will autofix during the weekend ...
> Denis, this mail just to tell you that the ticket [1] has been worked
> a bit upon, but needs much more work. It's a robustness issue which
> may or may not be worked-around of by adding a tolerance parameter
> to your toTopoGeom calls. Let me know if it does.
> [1] http://trac.osgeo.org/postgis/ticket/1613
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
