[postgis-users] Spatial join not finishing
Paul Ramsey
pramsey at opengeo.org
Wed Feb 29 15:15:57 PST 2012
Without a query plan (explain ... ) there's not much people can do but
scratch their chins sagely.
P.
On Wed, Feb 29, 2012 at 3:11 PM, Jorge Gil <j.a.lopesgil at tudelft.nl> wrote:
> Hi everyone,
> I've been trying to do a spatial join for a couple of days in different ways
> and it never seems to finish. I've done something identical before in a much
> larger set of the same data and it worked after a few hours.
> I have a polygons (buildings) table with 150,000 records and a points (land
> use) table with 170,000 records. I want to calculate how many points are
> within each building and add that total to the column 'units' in the
> buildings table. The query I run is this:
> UPDATE buildings as aa SET units=bb.count FROM (SELECT cc.gid , count(*)
> from buildings as cc, landuse as dd
> where ST_Within(dd.the_geom, cc.the_geom) group by cc.gid) as bb WHERE
> aa.gid=bb.gid;
> I also try to create a separate table with the results of the join before
> doing the update, but the first step also fails.
> Am I doing something wrong? Is there a simple trick that makes this more
> efficient?
> Thank you,
> Jorge
> Jorge Gil
> PhD Candidate
> TU Delft / Faculty of Architecture
> Department of Urbanism
> Chair of Spatial Planning and Strategy
> Julianalaan 134
> 2628 BL Delft
> P.O. Box 5043
> 2600 GA Delft
> The Netherlands
> www.tudelft.nl
> postgis-users mailing list
