[postgis-users] GISGRAPHY setup issue
Paragon Corporation lr at pcorp.us
Mon Jan 2 19:40:54 PST 2012
What you have looks right, but perhaps the account you are using to install
postgis.sql doesn't have rights to language or the port it default to is
different.
You could try doing using:
psql -U USER -h 127.0.0.1 -d gisgraphy -c "CREATE LANGUAGE plpgsql;"
In theory you should have same issue but you might get a different message.
Which version of PostgreSQL are you using?
You might also try postgresql general as I don't think this is a PostGIS
specific issue.
Hope that helps,
Regina
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ing.
Ramon Resendiz
Sent: Monday, January 02, 2012 3:38 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] GISGRAPHY setup issue
Hi all,
I’ve tried to install the GISGRAPHY to integrated it with OPENGTS, i’ve
successfully installed OPENGTS but when I tried to configure the POSGTIS
database to create the postgis function there is an error, that I couldn’t
found information about it, that why I’m recurring to you.
The issues is the following:
# create the database
psql -U YOURUSER  -h YOURIP -c  "CREATE DATABASE gisgraphy ENCODING =
'UTF8';" à OK
#create language
createlang -U YOURUSER -h YOURIP plpgsql gisgraphy à OK
Descripción: Descripción: cid:image001.png at 01CCC6F0.1A2B5580
#create postgis function
psql -U USER -h 127.0.0.1 -d gisgraphy -f
/usr/share/pgsql/contrib/postgis-1.5/postgis.sql à ERROR
There is some function that create without any problem until the next error
message appear:
psql:/usr/share/pgsql/contrib/postgis-1.5/postgis.sql:2024: ERROR:  language
"plpgsql" does not exist
HINT:  Use CREATE LANGUAGE to load the language into the database.
Descripción: Descripción: cid:image002.png at 01CCC6F0.1A2B5580
Even when i tried to import the file spatial_ref_sys.sql there is an error,
I try to figure out due the postgis.sql could not was imported correctly.
/usr/share/postgresql-YOURPOSTGRESVERSION-postgis/spatial_ref_sys.sql
Best regards,
RR
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120102/0d6f0634/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120102/0d6f0634/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120102/0d6f0634/attachment-0001.png>
