[postgis-users] shp2pgsql - how to continue when error occurs
Muhammad Imran
imranserver at yahoo.com
Tue Jan 3 00:21:21 PST 2012
Hi Lauri,
1- Disable or remove unique key (UK) on table.
2- Import data using shp2pgsql
3- remove duplicate rows using SQL
DELETE
FROM sometable
WHERE someuniquekey NOT IN
(SELECT MAX(dup.someuniquekey)
FROM sometable As dup
GROUP BY dup.dupcolumn1, dup.dupcolumn2, dup.dupcolum3)
(http://www.postgresonline.com/journal/archives/22-Deleting-Duplicate-Records-in-a-Table.html)
4- Enforce UK
-Imran
--- On Tue, 1/3/12, Lauri Kajan <lauri.kajan at gmail.com> wrote:
> From: Lauri Kajan <lauri.kajan at gmail.com>
> Subject: [postgis-users] shp2pgsql - how to continue when error occurs
> To: postgis-users at postgis.refractions.net
> Date: Tuesday, January 3, 2012, 1:18 PM
> Hi all,
> I'm trying to merge multiple shapefiles to postgis table. I
> know that
> there is some duplicates in different files.
> I thought that I could just check duplicatiness when
> loading shapes
> with shp2pgsql.
> So I first created an empty table and added a unique
> constraint to the
> field that I know to be unique with non duplicate records.
> But now when shp2pgsql tries to insert first duplicate
> record and
> error occurs it stops and won't load any records.
> Is there a way to continue when "key already exists" -error
> occurs?
> I read that in shp2pgsql that comes with 2.0 it has -e
> parameter that
> loads each record invidually. Is this the only way to go?
> Don't like
> that cause I have 13GB shape files. And I would like to use
> Dump
> dormat.
> Thanks
> -Lauri
> postgis-users mailing list
