[postgis-users] Postgis installation on sles 11 sp1
Otto Dassau
dassau at gbd-consult.de
Wed Jan 4 10:09:48 PST 2012
Hi Steve,
ok, then the Application:Geo packages won't work for you, because they
don't provide postgresql 9 for SLE_11.
I updated the Application:Geo:Postgres9PostGIS1 repository. It now provides
postgres 9.1.2 and postgres 1.5.3, also for SLE_11. Please try, if that
works for you. The packages will be available soon, also for SLE_11_SP1, I
guess.
http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/
Regards
Otto
Am Wed, 4 Jan 2012 11:05:59 -0500
schrieb Steve.Toutant at inspq.qc.ca:
> Hi Otto,
> I need postgis to work with at least postgres v9.0
> regards,
> Steve
> Otto Dassau <dassau at gbd-consult.de>@postgis.refractions.net
> Envoyé par : postgis-users-bounces at postgis.refractions.net
> 2012-01-04 09:49
> Veuillez répondre à
> PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> A
> cc
> Objet
> Re: [postgis-users] Postgis installation on sles 11 sp1
> Hi Steve,
> I recently (3 weeks ago) updated the postgis package for SLES 11 on
> Application:Geo to version 1.5.3. They built without any problems on SLES
> 11 and I think (didn't test), that they also work with the standard
> postgresql packages provided with SLES 11, but that's not version 9.1.2.
> Have you tried to use the standard postgres from SLES 11? I think it is
> 8.1.x?
> Regards
> Otto
> Am Wed, 4 Jan 2012 09:33:29 -0500
> > Hi,
> > I still can't make postgis work on sles 11 sp1
> > I successfully installed postgres 9.1.2-64.1 from this repository
> http://download.opensuse.org/repositories/server:/database:/postgresql/SLE_11_SP1
> > Then I installed postgis from this repo of sles11 (not sp1)
> http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/SLE_11
> > (also tried with this one
> > http://download.opensuse.org/repositories/Application:/Geo/SLE_11)
> > Everything went well but I when I tried to enable postgis running
> > postgis.sql, I got this error
> > psql:/usr/share/postgresql/contrib/postgis-1.5/postgis.sql:59: ERREUR:
> n'a
> > pas pu charger la bibliothèque « /usr/lib64/postgresql/postgis-1.5.so »
> > /usr/lib64/postgresql/postgis-1.5.so: undefined symbol:
> > DirectFunctionCall4
> > I also tried to compile postgis but I got this error
> /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld:
> > /usr/lib64/libxml2.a(parser.o): relocation R_X86_64_32S against
> > `.rodata.str1.1' can not be used when making a shared object; recompile
> > with -fPIC
> > /usr/lib64/libxml2.a: could not read symbols: Bad value
> > collect2: ld returned 1 exit status
> > Anyone successfully installed postgis on sles 11 SP1?
> > Any help or suggestions?
> > Thanks for your help
> > Steve
> postgis-users mailing list
