[postgis-users] error: undefined symbol: json_tokener_errors in POSTGIS2.0
P Mohan pmohan at neozon.net
Wed Jan 18 19:09:24 PST 2012
Thanks for the response. after you email i checked that angle.
Ubuntu Oneiric has /usr/local/lib included in the path you mentioned.
is there anything else that i am missing? gimme some leads that i can
pursue.
On Wed, Jan 18, 2012 at 7:40 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> Often times Linux distros will ship without /usr/local/lib in the ld
> path, so running ldconfig won't actually pick up libraries there. Edit
> /etc/ld.so.conf and add a line for /usr/local/lib then run ldconfig
> again.
> P.
> On Tue, Jan 17, 2012 at 6:59 AM, P Mohan <pmohan at neozon.net> wrote:
> > hi Strk,
> > i ran the ldconfig (load dynamic configuration) in the same directory as
> > json-c make.
> > then tried again, still getting the same error.
> > is there any thing else that i should check?
> > thanks
> > pmohan
> > On Tue, Jan 17, 2012 at 4:15 AM, Sandro Santilli <strk at keybit.net>
> wrote:
> >> On Tue, Jan 17, 2012 at 01:40:51AM -0500, P Mohan wrote:
> >> > /usr/lib/postgresql/9.1/lib/postgis-2.0.so: undefined symbol:
> >> > json_tokener_errors
> >> >     installed json-c from source from github
> >> As root, run:
> >>   # ldconfig
> >> --strk;
> >>  ()   Free GIS & Flash consultant/developer
> >>  /\   http://strk.keybit.net/services.html
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120118/35fc95bf/attachment.html>
