[postgis-users] QGIS Plugin PostGIS Manager
Florian Beyerbach
Florian.Beyerbach at gmx.de
Fri Jan 20 12:51:03 PST 2012
hi,
thanks for the first idea to solve the problem.
i use the tool terminal and the path environment variables are:
mbp-wlan:~ fbeyerbach$ echo $PATH
/sw/bin:/sw/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin:/usr/X11R6/bin:/usr/local/pgsql/share/contrib/postgis-1.5/:/usr/local/pgsql-9.1/bin:/usr/local/pgsql-9.1/bin
i think this should work. any idea?
Am 20.01.2012 um 20:18 schrieb Giuseppe Sucameli:
> Hi Florian,
> On Fri, Jan 20, 2012 at 7:54 PM, Sandro Santilli <strk at keybit.net> wrote:
>> On Fri, Jan 20, 2012 at 07:14:07PM +0100, Florian Beyerbach wrote:
>>> it is the first time i use this community support. if i make any mistake i´m sorry.
> I think this message should be sent to the qgis-user mailing list
> as the plugin is a QGis plugin.
>>> i try to use the PostGIS Manager Plugin 0.5.15 for QGIS 1.7.3 with the postgresql 9.1 and postgis 1.5.3 database on my MacBookPro with Mac OSX Lion 10.7.2.
>>> know i want to "Load Data from Shapefile", i chose the shape file in the dialog and after i click the load button
>>> i get the error message: "Message: Filename: None".
> PostGis Manager assumes that shp2pgsql executable is in PATH
> environment variable. It's unable to find it, so it throws an OSError
> exception.
> I'm sure that after adding shp2pgsql to the PATH env var it should
> work fine, but I've no Mac so I cannot say how to do this...
> I hope this helps.
> Regards.
>>> I have no idea what the problem is, can anybody help me?
>> I think the db_manager plugin superceeds the PostGIS Manager one.
>> Giuseppe (in Cc) is the author of db_manager, but can probably also
>> help with the PostGIS Manager plugin.
>> --strk;
>> () Free GIS & Flash consultant/developer
>> /\ http://strk.keybit.net/services.html
> Giuseppe Sucameli
