[postgis-users] Running PostGIS 2.0 on 64 bit machine
Joan
wamaithajoan at gmail.com
Tue Jan 24 11:29:29 PST 2012
Thanks Bborie, I am now on the right track.
Joan.
On 24 January 2012 15:47, Bborie Park <bkpark at ucdavis.edu> wrote:
> Hey Joan,
> You must be using an older build of PostGIS 2.0 as raster2pgsql.py is
> no longer supported. You will want to download and use the latest
> Windows Experimental builds.
> http://postgis.refractions.net/download/windows/experimental.php
> Look for the links under the text...
> "These are 32-bit binaries so will not work on 64-bit PostgreSQL. We
> are working on getting 64-bit binaries out as well, but are running
> into some stumbling blocks. For the time being -- if you are on
> Windows 64-bit, you must install the 32-bit PostgreSQL to use these."
> Also, there are no 64-bit builds of PostGIS available yet due to
> compilation issues.
> Hopefully that gets you back on track.
> -bborie
> On Tue, Jan 24, 2012 at 5:19 AM, Joan <wamaithajoan at gmail.com> wrote:
> > Hi,
> > I have been trying to set up PostGIS on a 64 bit machine running windows
> 7.
> > The installation was successful but when I run the raster2pgsql script I
> get
> > the following error.
> > Traceback (most recent call last):
> > File "C:\Postgresql\bin\raster2pgsql.py", line 34, in <module>
> > from osgeo import gdal
> > File "C:\Python27\lib\site-packages\osgeo\__init__.py", line 21, in
> > <module>
> > _gdal = swig_import_helper()
> > File "C:\Python27\lib\site-packages\osgeo\__init__.py", line 17, in
> > swig_import_helper
> > _mod = imp.load_module('_gdal', fp, pathname, description)
> > ImportError: DLL load failed: The operating system cannot run %1.
> > I have gdal in C:\Program Files (x86)\GDAL and C:\Program Files
> > (x86)\GDAL\gdal-data in the environmental variables
> > Any ideas??
> > Joan
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120124/6a126013/attachment.html>
